Question about Canon PIXMA MP240 All-In-One InkJet Printer
P2 error - Canon PIXMA MP240 All-In-One InkJet Printer
  • 47 Answers
P02 (Carriage error)
  1. Make sure no foreign material stuck to the print head railway.
  2. Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.
visit this link for more info
http://pcmediks.blogspot.com/2010/10/canon-pixma-mp258-error-code.html
Posted on Dec 28, 2010
Just use a soft dry tissue and clean the thin transparent strip gently and make sure that it is transparent all along the strip. You have to open the printer from the front to do this and to get to where the printer head stands turn it on and the head will park in the middle so that you can clean the right side of the strip.clean both side of the strip back and front. Then all should work as is, it worked for me.
Posted on Dec 19, 2011
What does error code p2 mean on aura systems au-021-co-qc
you can usually look this stuff on the Internet by simply entering the information in some type of string such as "explain error code p2 aura systems...." about like you have the question. You can usually hunt it down.
Jack
Apr 02, 2015 | Cars & Trucks
I have failed to reset error 5011 and P2 on my canon mg2100, please help
On my Canon MP 240 the P2 error code was because the belt which drives the cartridge unit had slipped off, so the motor turns but the cartridge unit doesnt move. Just make sure the belt is fitting over the cog correctly. As you look into the printer from the front - the cog is on the left hand side. This took away the P2 error code message on the lcd.
Oct 05, 2013 | Office Equipment & Supplies
Kitchenaid microwave error f6e0
1. Unplug oven or disconnect power.
2. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step 6.
- If they are plugged in, go to step 3.
3. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ohm . If any of
these measurements exceeds 5 ohm, go to step 5.
4. Replace the appliance manager. Ensure all connectors are properly inserted.
5. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
6. Replace all parts and panels before operating.
7. Plug in oven or reconnect power.
8. Observe for longer than 1 minute to determine if error has been repaired.
9. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step 1.
At step 4, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
May 15, 2013 | Cars & Trucks
P2 error, replaced rinse probe, hi limit thermostat, still have an error p2
P2 error is the final rinse probe. Depends on the model of the D/W for location, next to the vac breaker.
Apr 26, 2012 | Hobart AM15T Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Robotic sound on samsung p2!
there is a new firmware 5.10 which should fix it. Now only to figure you out how to upload the new firmware since EmoDio does not see it.
Here are the firmware notes for 5.10
YP-P2 Firmware Ver 5.10
<Improvement>
1. Error correction : 22.5kHz file''s playback noise (UFO / siren noise)
2. Error correction : Page scroll error on 2page or higher VCF file
3. Error correction : Power key operation on Hold mode
4. Error correction : Track playback error on specific conditions
http://www.samsung.com/us/support/download/supportDownDetail.do?group=tvvideoaudio&type=digitalaudioplayermp3&subtype=mp3flash&model_nm=YP-P2JCBY&mType=FM&dType=G&cttID=2009329&disp_nm=YP-P2JCBY
Nov 02, 2008 | Samsung Yepp YP-P2 Digital Media Player
Nikon coolpix p2 lens error
You can disassemble the lens and clean the dust. Here are some photos of the disassembled P2 Lens http://fixit.limewebs.com/p2/
Aug 21, 2008 | Nikon Coolpix P2 Digital Camera
Mp3
my computer dont read my p2
Jun 08, 2008 | Samsung Yepp YP-P2 Digital Media Player
Canon PIXMA MP240 All-In-One InkJet Printer Logo
2,538 people viewed this question
old marine
old marine
