Hi there! You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice, Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker. Pilot orifice for propane has smaller bore than of natural. Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner). You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com Regards.
You will need to conact a gas safe engineer who will change your gas jets from natural gas to LPG, then carry out various test to makesure your flueless appliance burns the gas safely and efficiently
check the supplier for the conversion kit.the kit contains burner orifice, pilot orifice and gas valve spring which are commonly needed for conversion from propane to natural gas or from natural gas to propane. ****natural gas orifice has larger bore than propane, gas valve spring for propane is thicker than for natural gas.
I know from working on piles of restaurant equipment, that when you change over from natural to propane, you have to change the orifices and the regulator. Most natural gas equipment needs 3.5-4.0" of W.C. (that is, water column) and most propane gas equipment needs 9.0-11.0" W.C. The density and specific gravity of the gases are different. If it is glued so as you can not make any adjustments to the pressure, change the regulator to a propane one. Most natural gas regulators can not be adjusted to the propane pressure needed. Please be careful as working with gas can be dangerous. Natural gas is usually lighter than air and will rise but propane is heavier and will "pool" or "puddle" in low areas and can cause explosions in the right circumstances.
You need to adapt your range for the propane gas. You need to change the orifices, propane needs a larger opening than natural gas. If you contact your propane company they can help you and some will even do it as a free service (or used to).
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
hello need model number off of the sticker and serial number
