Question about Motorola Mobility Motopure H12 Bluetooth Headset
How to reset motorola h12? - Motorola Mobility Motopure H12 Bluetooth Headset
Problem with the Motorola Motopure H12 Bluetooth Headset I can't hear anything on my h12 headset. other people can hear me but i can't hear them.
Hi.
I'll really advise you to perform a FDR on the bluetooth. You will need to Press and hold the Call button while turning on the headset to turn on Reset to factory default. Follow the voice prompts to make changes to the settings.
You can find this information on the Link How do reset my FINITI to factory default
Hope it helps.
Marge
Motorola Mobility.
Aug 06, 2014 | Motorola Mobility Motopure H12 Bluetooth...
How to reset my h12 bluetooth headset ?
Hold in the button for 5-10 secs till the light flashes twice.
Jan 17, 2011 | Motorola Mobility Motopure H12 Bluetooth...
Can't sync H12 from LG Cell Phone to New Blackberry
took me a minute, but i figured it out on mine.  Without using the alt button, type 0000 then hit enter.  Hopefully this will work for you as well.
Mar 04, 2009 | Motorola Mobility Motopure H12 Bluetooth...
PIARING MY MOTOROLA RAZOR V3 WITH MY MOTOPURE H12
turn your bluetooth on and on your phone go to bluetooh or settings(if not under bluetooth) and select trusted devices or pair devices, then on the left or right corner it will say (search) once you have found your bluetooth it will say(motopure h12) select and then it will say pair device and you put in the code that came and your instructions and your good to go.
Feb 27, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motorola Bluetooth Headset MOTOPURE H12
My H12 manual has the passcode as 4 zero's for most phones.
Feb 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motorola H12 connection to more than 1 phone?
to my knowledge the phone will tell you you have some back ground action on the bluetooth and i dont belive it has that feature
Jan 25, 2009 | Motorola Mobility Motopure H12 Bluetooth...
How to pair Motorola H12 with iphone?
I just figured it out myself!!
here is how:
1.) press your home screen button at the bottom of your iphone
2.) open settings
3.) go into your general settings (same gear picture as home page)
4.) touch to open bluetooth
5.) turn on your H12 headset and place close to your iphone
6.) turn on bluethooth on iphone and it will automatically find the headset
7.) touch the motorola H12 button and it will enable the connection
Jan 08, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Help pairing my H12 bluetooth
I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
Motorola Mobility Motopure H12 Bluetooth Headset Logo
394 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
