Question about ASUS Eee PC 900 Notebook
How do i reboot my pc without no cd drive? - ASUS Eee PC 900 Notebook
  • 600 Answers
Every time you turn it on it boots...If you mean how do you reinstall the operating system then you can use USB flashdrive or external cd/dvd drive
Posted on Dec 29, 2010
My desktop frequantaly booting what can i do
When you say frequently rebooting; Is it randomly rebooting without warning? Do you get a BSOD (Blue Screen of Death) error message? Or does the PC just reboot without any error's other than windows was not shutdown properly?
MOST random reboot issues are caused by Power issues;
-Failing Power Supply
-Blown Capacitors on the motherboard
-Insufficient power to run the system.
These would be a good place to start to troubleshoot if you do not get a Blue Screen Error Message.
-Failing Hard Drive can cause this issue as well but is usually acompanied by a Blue Screen Error of sorts.
-Failing RAM again usually accompanied by a Blue Screen Error.
You can test for failing hardware, by using Hiren's Boot Disk for diagnostic tests on your Hard Drive or Ram.
Hiren's Boot CD 15.2 - http://www.hirensbootcd.org/files/Hirens.BootCD.15.2.zip
You will want to run memtest X86 to test the Ram or Hitachi's Drive Fitness Test or SeaTools to test your hard drive.
This BootCD is not for the typical end user whom may not know there way around the features and options this Tech CD provides.
You will want to burn the Hirens Boot.ISO file to a CD (Burn Image Option) using any of your favorite flavors of burn software.
Hope this helps.
You can also download these diagnostic test individually such as memtest x86 and Hitachi's DFT or SeaTools independently from the Boot CD just by doing a google search. This might be the easier way to perform these tests for people who aren't very savvy with boot CD's.
Dec 09, 2013 | Intel D845GVSR Motherboard
To reset password on windows 7
Have you lost windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Jun 27, 2012 | Computers & Internet
I restored my acer aspire one back to factory settings without a back up device. when I try to restore from disk with an external cd. it says my disk is incorrect. it was the disk that came with it.
In that case, only the seller can solve it replacing the disk or your CD drive that I did not want to mention but seems to be your problem. Before calling them, try to disable the CD driver in Control Panel, reboot, Enable the driver, reboot and try the cd again.
Aug 10, 2011 | Computers & Internet
Pc running xp does not recognise cd or dvd drives. since windows update
had this prob...control panel;system;device manager;drives;cd/dvd disable;reboot xp;go back to device manager;enable drives;reboot...hope this helps
Mar 07, 2010 | Dell Dim.9150 Pentium D 820 Dual...
Pc freezes when I click open on my nec nr 7900a cd-rw. dell pc, software windown xp,
this is most likely an interface issue either on the motherboard or drive....could be software but dvd drives don't last forever. when booting press delete and let it go into bios setup. You don't need to change anything in bios, just try opening the drive. If it opens without delay remove any disc. Reboot PC and see if the drive behaves, If it's still being awkward, with the PC unplugged open up the PC and remove the drives data cable. Start PC, close down PC. Reconnect drive (use a different IDE /SATA connection if possible) Try DVD drive again. If the fault still persists, It's most likely the drive. Get a new one they are really cheap.
Aug 02, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
Blue screen error, no cd or flop drive, need usb reboot if poss
Obviously you need an XP CD--see if you can borrow one from someone. If you can, start the computer, press F12 to get the boot menu, and when it starts from the CD wait until you are prompted to choose an option. Choose R to repair and follow the prompts to get to the C:\ prompt. Type chkdsk /r to repair the file system. If that works, you should be good to go.
Can't get an XP CD? Try this option:
http://www.ultimatebootcd.com/download.html
May 24, 2009 | Dell Latitude D600 Notebook
How do i install without the CD-ROM
when you connect a new pc to your modem, reboot the modem (by unpluging power and reconnect power & it will automatically detect the pc,
then reboot the pc and you will be connected ...
with xp no driver needed
Apr 12, 2009 | Arris SURFboard® SB5101 Cable Modem
Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Mar 11, 2009 | Dell Dimension 2350 PC Desktop
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
ASUS Eee PC 900 Notebook Logo
70 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
