Question about Electrolux Epic 6500 Vacuum
The "change bag" light has
  • 694 Answers
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Posted on Dec 29, 2010
Where is vacuum chamber on a Windsor sensor xp12
it comes up from the back,it is probably plugged or the sensor is dirty
Apr 21, 2015 | Windsor Vacuums
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
Light on for "full bag or clog." I changed bag,
Check the airflow tube behind the brush. This is a common place for clogs. The hose is more common, especially at elbows, like where it attaches to the tank. Another possibility is a dirty filter. Check this first to rule it out, then check the rest.
Jan 26, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
How to reset?
The button I think you are talking about is the bag switch. It is located in the bottom right corner where you put the bag. If the bag does not cover it, the machine will not run.
Also, when the machine cuts off when the bag is full, you have to push the power switch off and back on to reset the full bag switch located in the switch control housing inside the machine.
Mar 13, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux upright bag light stays on even when bag is not full
Once you change the bag, be sure to turn the machine off and back on to clear the fault. If it is the full bag light that is on, and not the "?" light, and you have a new bag in place, then you probably have a bad control valve. I would suggest finding the closest Aerus (formerly Electrolux) dealer and having them change it. It shouldn't be too expensive. If you have the "?" light illuminated, the bag probably isn't pressing the actuator like it should. When placing the new bag into the machine, be sure the bag top presses the small button in the lower right hand corner. Good Luck!
Jan 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
128 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
