Question about Eureka Enviro Steamer 310 Stick Vacuum
My Eureka Enviro Steamer won't make steam. It is only my second time to use it. It came on for about 5 minutes, then the steam stopped. The green light stayed on. I turned it off and let it cool down, added more water, then turned it on again. It didn't do anything--not even warm up.
  • 59 Answers
SOURCE: Eureka Hotshot Enviro steamer
Remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Posted on Oct 26, 2008
reddevil6
  • 1673 Answers
SOURCE: Leakage from eureka deep steam carpet claeaner
You will just have to take it apart to see if a hose is loose, came off, or is cracked.
Posted on Jun 17, 2008
SOURCE: I WAS GIVEN A EUREKA
Eureka.com has your manual online for download.
Posted on Feb 05, 2009
  • 62 Answers
SOURCE: my parents have deluxe enviro steamer eureka they lost instructions on how to use
try this link http://www.eureka.com/service/manuals/70359.pdf
Posted on Apr 14, 2009
tknalty
  • 121 Answers
SOURCE: I have an electrolux enviro multi steamer and have
Check the handle. There is a Button which you press and hold and one which slides up and down. The slide button is so you don't have to depress the other button (when you are wanting constant steam, ie., for cleaning floors etc...).
I would suggest that the slide button is engaged (meaning in the on position), slide it back the opposite way and see if this solves the problem. Regards, Tina
Posted on Feb 08, 2010
I just was given a Eureka Enviro Steamer model 370A. I don't have an owners manual, & I plugged it in, light came on, but no steam. Nothing! Help!
click the link below for manual
http://static.fixya.com/Manuals/E/Eureka/nvr_Stmr_370_C3B7174F51D011C6ACD46F513524BC9D.pdfhttp://static.fixya.com/Manuals/E/Eureka/nvr_Stmr_370_C3B7174F51D011C6ACD46F513524BC9D.pdf
Sep 06, 2013 | Vacuums
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
My Eureka Deluxe Enviro Steamer doesn't steam, I had no directions with it so I'm not sure how much water to put in it. It comes out the bottom before it heats up sometimes.It never seems to get hot...
You will need to pour two measures of water using the measuring cup or 12 oz of water. The reason why water comes out of the bottom is because the floor cloth is too wet or you had too much water in the tank
Click on the link below to view the owners manual:
Jun 22, 2010 | Eureka Deluxe Enviro Steamer Vacuum
What is the difference between the 2 eureka enviro steamers: the 310 model, and the 313A? are they doing the same job, and which one is a better buy i.e., does the job, and does not cost an arm and a leg...
Greetings,
The Eureka 310 Envirosteamer is no longer made. Eureka discontinued this particular model several years ago. It was a very highly rated steam mop at the time, so Eureka came out with a new model that had a very upgrades which was the Eureka 312, which is also now discontinued. These two old models are discontinued because Eureka has introduced the 313A which is the best model they've made to date. This is the most current, and only upright steam mop that Eureka makes currently, so if you are going to buy a Eureka, the 313A is the one that you want to buy. It's a great steamer I think. We do offer a 60 day full money back guarantee with any purchase, I hope you will consider us when you're ready to go for it.
Please feel free to request a clarification here on Fixya if you have any questions I can answer further for you.
I hope this was helpful information for you. If this was helpful, please rate it as helpful by clicking on the thumbs up icon in the lower right hand corner.
Thank you so much,
Chris J.
Mar 17, 2010 | Eureka Enviro Steamer 310 Stick Vacuum
Jun 08, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Need directions on how to clean clogged steam nozzle
If your steam mop is Enviro Steam Mop by Eureka. remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Apr 06, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Lost Manual
You didn't mention brand or model #, but try going to the manufactures web site and see if they offer manual downloads.
Oct 31, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Eureka Enviro Steamer 310 Stick Vacuum Logo
448 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
