Question about Frigidaire Electric Dryer
When we turn the dryer on it seems like it will run but stops and gives us a e9e code where the time should be. Model number AEQ7000ES1
  • Frigidaire Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. After reading the service manual, the E9e code is a line voltage problem. It is cause by low voltage or intermittent voltage. This could be a loose connection in the dryer plug or at the terminal block. There can also be a problem with a hot terminal connection cause by a loose terminal. It can also be a problem with your local utility power. Voltge has dropped below 215VAC to cause this code to appear. My suspicions are a loose / hot connection either at the wall connection or dryer terminal block. You may have to replace the dryer cord or receptacle. Possibly even replace the terminal block if it has been damaged. You should also check to see that your main CB for the dryer is properly seated in the power panel. If it is not seated correctly it can also cause this symptom. Press the CB to OFF by physically pushing it to the OFF position and then back to ON. By doing so you did a complete reset of both CB power connections internally. Press hard on the face of the CB with your thumb to make sure it is seated in the power panel. Pressing cancel should clear this fault after repairs have been completed.
The repair manual can be found here: Fault code is listed on page 16 of the link to the left. The terminal block connections are on pages 37 and 38. Just note there is a major difference between a 3 prong and 4 prong power cord connection. The terminal block ground is re-configured for a 4 pronged plug. If you have to replace the terminal block make a hand written diagram FIRST! Number the wires with marked masking tape if you have too. I am pretty certain that when you find the source of the low voltage problem your dryer will be fine. Currently it is reacting to low or intermittent input power.
Thanks for choosing FixYa,
Kelly
Posted on Dec 29, 2010
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
My 1988 washer/dryer combo Model LSG1000 is showing an E9 code for the dryer. Do you know what that means?
The "E9E" code means Low Voltage is seen at the Control Board. Make sure the RED wire on the Control Board that connects to the Heater Relay is not loose or burnt. This is the LINE ONE voltage supply to the Control Board and if it has a bad, loose or burnt connection it will cause E9E to display. If there are no loose of burnt wire connections then the control board will likely need to be removed and replaced.
Aug 16, 2011 | Maytag Dryers
Dryer does not stay running. Press the start button and sometimes it starts and sometimes not. Won't stay running. Seems to heat ok. Sometimes displays E9E on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Jun 09, 2009 | Frigidaire Dryers
KENMORE MOD. 417.84092....RUNS FOR A MINUTE ORTWO OR FIVE / STOPS. HEATS UP OK BUT WON'T RUN FOR MORE THAN A FEW MINUTES. ERROR CODE E9E.
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
Apr 25, 2009 | Kenmore 67082 Electric Dryer
My affinity frigidaire dryer keeps flashing an E9E error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire dryer
it sounds like the programer on the drying side has had its day
Dec 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire  Electric Dryer Logo
329 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
