Question about Lakewood 792/JR Utility Heater
Lakewood Model 792/A My heater has stopped working. The light indicates that it is receiving power. I checked the tip switch to see if stuck open. OK Next step please? Jeff
    Novelist:
    Champion:
  • 224 Answers
Separate the case and trace out the wiring you are looking for an over heat limit switch. These are usually at the top of the case. You should also go over the element with a volt ohm meter make sure it is good, once you locate the thermal overload check it with the volt ohm meter it should read closed or dead short. If it reads open here is your culprit. It has been my observation that replacement parts can generally cost as much as replacing the entire heater. These I can pick up all day long for $19.00 at Home Depot the call them milk house heaters. Good luck with the repair.
Posted on Dec 29, 2010
The switch 750/1500 watt doesn't work
Replace it with any rated double throw double pole switch. Continuity check the switch first, to be sure it's the switch that's the problem.
Dec 11, 2013 | Lakewood 792/JR Utility Heater
Find tip-over switch on Lakewood Heater
lakewood makes several styles of heaters,if it is the steam looking version,i don't think it has a tip over switch,because it cant start a fire...the tip over switch version has the counter balance switch in the casing under the coil and fan area..to check to see if it is working ,just turn it on and tip it over ,try it a couple of directions,if it shuts off it works.its not a thermocouple...
Nov 28, 2012 | Lakewood Oil-Filled Electric Radiator...
Where can I get a replacement thermostat for a Lakewood 792/JR space heater?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Nov 06, 2010 | Lakewood 792/JR Utility Heater
What to do if my lakewood 729 jr utility heater wont come on it on ly glows
sounds like your fan is not turning you may need to unplug and try to move the fan motor by hand this may take a few tools to open the unit and see if its stuck if it is try sprayin the motor shaft with wd if ti turns by hand
Apr 09, 2010 | Lakewood 792/JR Utility Heater
My lakewood oil filled heater model 5600/7 just stopped working. It won't turn on..no lights. There is no history of tipping over.
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Apr 06, 2010 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Lakewood heater 792/AA Fan works and pushes warm air, but element/coils never heat up where heater actually gets hot.
sounds like a broken element or wire. with unit unplugged, using an ohm meter check all connections and check elements for resistance.
Jan 13, 2010 | Lakewood 792/c Utility Heater
LAKEWOOD HEATER DOESENT HEAT UP
take it apart they should be aglass fuse inside
Dec 24, 2009 | Lakewood 792/JR Utility Heater
Model 7096 heater
http://www.ul.com/media/newsrel/nr041405.html
Concerning Lakewood Model #7096
RECALL
May cause electric shock!
Nov 20, 2007 | Lakewood Oil-Filled Electric Radiator...
Lakewood 792/JR heater running w/o heat
Hi Spybotics. I have the same problem and I traced mine down to a burned out over-heat fuse link. Check out my recent post. My guess is that you are having the same problem as me. It's not hard to tell - just take off the rear panel and test the link (looks like a small resistor in line with the element) with an ohm meter. Open circuit means burned out fuse link. DO NOT bypass the link, as an extreme fire hazard will exist without it.
Apr 14, 2007 | Lakewood 792/JR Utility Heater
Lakewood 792/JR Utility Heater Logo
725 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
