Question about Siemens HF26056GB 1000 Watts Microwave Oven
Microwave keeps cuting out - Siemens HF26056GB 1000 Watts Microwave Oven
Sparks form the right side inside the microwave
take it in for a proper diagnosis
there are to be no sparks from a microwave inside or outside
Dec 05, 2016 | Microwave Ovens
My microwave keep working when I open the door and it is stopping when I close the door.Then working normal but I cannot keep my door open, it keeps running. What can I do??
First, It is very very dangerous for a microwave to run with door open. The door is also a shield to protect you from the microwave radiation. There should be a safety interlock to prevent this from happening. DO NOT USE the microwave! Seek out professional repair or replace the unit.
May 20, 2015 | Microwave Ovens
The door on the combination oven/microwave slammed shut and all the power cut off from it
1 check main cable connection maybe its pull uot or cuted from fuse bass
Nov 27, 2013 | Bosch Microwave Ovens
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
My maytag over the oven microwave just died;
most likely the power supply in the microwave is gone. the microwave die probably it is over the oven. heat from the stove cause the microwave to heat up and cold off more than it is on the counter.
counter microwave has fan and air slot in the rear. it keep the motor and microwave cool, and there nothing else to keep it hot. but the over the oven, the only ventalation is from the top. and with the added heat from the stove top and oven.
Apr 27, 2009 | Maytag MMV4205 Microwave Oven
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
How to change the fan
The fan is located on the right side behind the key panel. I know this because I removed it while replacing the magnetron the other day. It is easier to get to than the magnetron. You take the black cover off. Then there is a silver cover with 3 screws covering the magnetron. Remove it and remove the front grill and one screw to the keypad, then you can reach the fan thru there.
i hope this helps!
Oct 28, 2008 | GE JVM1631 Microwave Oven
Siemens HF26056GB 1000 Watts Microwave Oven Logo
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
