Question about Western Digital Westen Digital WD1200VE 120GB U100 2.5-Inch 9.5mm Notebook 120 GB Hard Drive
The unit is plugged in but the computer doesn't show that it is connected?, you have any ideas of whats going on?
  • Western Digital Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Dec 28, 2010
My kdc mp322 shows no AUX also when I go into the menu it doesn't display ! Please help I'm so pist !
My daughters unit (different from yours) didn't show AUX on the menu until something was physically connected to it. Plug your MP3 or whatever in and see if the menu then detects it. HTH
Dec 23, 2012 | Car Audio & Video
How to connect to a pc
Install the software first, then connect the usb and power cables, then turn on the unit.
Here is a section of the installation manual :
Software Installation
1. Do not connect this device to computer yet.
2. Insert the utility CD into computer's optical drive, and then the installation window should
automatically appear on the screen. If the installation window doesn't show up, go to "My
Computer" and browse the CD. By executing the "index.html" file, the installation window
will appear.
3. Click on "Private Folder Manager"/ "Playlist Manager", and then follow the on screen
instructions for installation.
4. After the software had been successfully installed, see [Connecting to USB] for cable
connection.
Connecting to USB
1. Connect the plug of AC adapter to the connector marked "DC IN", plug the other end into
an electric outlet.
2. Connect the USB cable to the USB connector. Then connect the other plug to computer's
USB port.
3. Press the Power switch and then the blue LED will light up.
4. The computer will detect this device and you can start accessing the drive.
Jul 13, 2011 | Argosy HV372T Mobile Video HDD Media...
I got error on printer LBP2900 when connect to my laptop (windows 7) It show communication error but usb connection and software installation no problem. Any idea about it?
Most likely it is a corrupt software installation.
You can try the easy things first: 1) Unplug the USB cable from the computer 2) Reboot 3) Plug the USB cable back into the computer, see if the communication error happens again
If that doesn't work, time to reinstall the software: 1) Go to Control Panel > Add Remove Programs OR Programs (depending on which version of Windows you have) 2) Remove every piece of software related to your printer 3) Unplug the USB cable from your computer 4) Reboot 5) Disable any Anti-Virus or Firewall software that you have running 6) Re-run the printer installation software
Jul 04, 2011 | Computers & Internet
I have a garmin nuvi 200. I'm having problems trying to charge the device. I have tried charging it in my car as well as the computer. Once I try charging it a black screen appears that says garmin as...
This is meant to happen when it's connected to your computer but not to your car charger. Sometimes it happens, when connected to a car charger, because the mini USB plug on the charger lead doesn't go in far enough into the satnav. It feels like it's fully in but it's not. If you push it in further it should solve the problem.
It takes 8 hours approx to charge a satnav connected to your computer but only 4 hours approx with the car charger or mains charger.
Apr 22, 2011 | Garmin nuvi 200W GPS Receiver
My Sansa Fuze says it does not have any space left.. yet there is nothing on it! I cannot transfer anything. Any idea what is going on?
Try to format it in Fat 32 format. Plug it into computer and select " Open folder to view all files" Then go to My computer/Computer (depending on what windows your using) Right click on the drive your unit is showing in and select format. Do a full format and make sure the FAT 32 option is selected.
Feb 25, 2011 | SanDisk Sansa Fuze MP3 Player
When it is plugged in only shows a picture and a picture of computer that shows system been connected to it.
Nuvi will show a picture of unit when plugged in to computer, its charging, connected this way is a slow charge.
You also use this way to update any maps or firmware for your unit.
If you have a new Nuvi.... and you are looking to set it up, you must first register to Garmin to unlock the maps its free.
Go to www.MyGarmin.com your unit will be detected and map unlocks will proceed
Aug 31, 2010 | Garmin nuvi 260W GPS Receiver
Power problem - led shows the ac plug is in - battery does not charge - can not run laptop on ac adapter - what is causing this problem
The connection to the power supply inside the Pc is or has gone,
because your using the connection 1000 times a year, it faulters, and fails.
$150/$200 to get repaired.
Strip out the laptop solder connection back up,
rebuild, very common problem.
Regards
Richard.
Apr 18, 2009 | Toshiba Satellite A135-S4527 Notebook
File Explorer won't show SD Card
the PVR-H140 unit doesn´t support the SDHC cards, only the old fasion SD cards are supported, sorry :(
Sep 30, 2007 | Mustek PVR-H140 Digital Media Player
My sansa e200 is not recognized by my pc
Have you tried changing the USB format? Go to the settings option on your sandisk and look for USB Mode. Change is to MSC (if that doesn´t work try MTP). When you connect it, it should detect the player.
May 10, 2007 | SanDisk Sansa e250 MP3 Player
Open Questions:
See all Western Digital Westen Digital WD1200VE 120GB U100 Questions
Western Digital Westen Digital WD1200VE 120GB U100 2.5-Inch 9.5mm Notebook 120 GB Hard Drive Logo
69 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
