Question about ASUS K50IJD2 Notebook
I am trying to figure out where to get my driver updates from. For months now, I have had some problems with video looking scrambled. Also, I continue to have problems with the audio not cutting on when I turn on the computer. I have to restart the computer to get it to cut on. This usually works, almost every time. ASUS K50IJ. I have Win 7, 64-bit home premium. Pentium Dual Core T4400 @2.20 GHz. Mine is 3GB. It is the one from Best Buy
  • 157 Answers
It supports the 1.86Ghz dual core so I would assume it also supports the 1.73
Posted on Jun 18, 2009
  • 8197 Answers
SOURCE: how do I disable touch pad when using a mouse?
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
Posted on Dec 30, 2009
  • 91 Answers
SOURCE: I am using Asus M2N68-AM Plus motherboard and AMD
dude check out if any part is overheating using speedfan software
if not check if your PSU can take the load of your PCparts
Posted on Feb 01, 2010
  • 12 Answers
SOURCE: Asus P5KPL-AM SE no audio
try to check ur cd driver(written there is that cd is working on windows vista). ur mboard is high-end and most of the driver is compatible to windows vista or higher operating system. you can actually download the driver thru the internet and make sure that the said driver is window xp compatible.
Posted on Mar 31, 2010
Posted on Apr 16, 2010
I have a HP 6930 notebook with a scrambled display. Looks like how comcast used scramble Pay channels. I tried the usual suspects driver etc. An external monitor works fine.
If it works ok on an external monitor, the driver or the video adaptor is wrong. If you have recently bought it from Amazon (in the last three months) I would return it as "not fit for purpose" and get them to correct it.
The correct driver can be obtained from HP here
Feb 05, 2015 | HP Computers & Internet
The most probable cause is that your video driver is not up-to-date. Try updating your video drivers as soon as possible. You can download all the latest drivers (for Windows XP only) for your laptop from here.
Download all Drivers for Xp
For other Operating Systems, just search online for the drivers compatible for your laptop model mentioning the OS.
Dec 14, 2010 | HP Pavilion dv9000z Notebook
Inspiron Core i5 Laptop. Error: Display driver stopped responding
Hi there!
You mentioned that's a 2 month old laptop,
From what i'm seeing here you should at least have 1 year of warranty with it if you purchased it online,
For the issue you have there,
Might want to specify what video card you have there.
For the drivers, go to then enter your service tag, make sure your select the right operating system, then you'll be able to see the drivers, update the video card driver and the BIOS,
If the problem persist go to nvidia and check your video card if they have released a new driver update,
Worst case scenario is replacing the video card.
Hope this helps!
May 27, 2010 | Dell Computers & Internet
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
My screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
Apr 05, 2010 | Computers & Internet
Hp pavilion 9000 gets scrambled screen and fails to start, scrambled screens occour when tabbing out of a game or wakeing from sleep
Sounds like a driver problem. Make sure you have all the updates. If the problem started after a recent update, a driver rollback may be needed.
If it is not the driver, then it might be a setting in the way your laptop handles video. Go into your ATI or nvidia setting under control panel. Review all of your setting and make sure nothing unusual is set, or find a 'restore to defaults' button if it has one.
Jul 03, 2009 | HP Pavilion DV2000T 14.1" NOTEBOOK LAPTOP...
Scrambled picture with DVD or Video Game
You have a bad digital board. Expect to spend some serious money to repair this.
Feb 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Power up fixed but still have scrambled colors
you will need to test some components at the tuner and check the tuner for any bad solder on it , although the tuner may be going bad testing the components around it may find the problem
Dec 29, 2008 | Polaroid FLM-3732 Television
ASUS K50IJD2 Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
