Question about Fuji FinePix S7000 Digital Camera
Why dose my camera say SD protecetd? - Fuji FinePix S7000 Digital Camera
  • 2,296 Answers
Your SD card is locked meaning is write protected. To unlock it you need to slide the small plastic toggle out of the 'lock' position. See image below
Posted on Dec 28, 2010
  • Fuji Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
An error message came up and said picture not formatted. The manual says it supports JPEG. So how do I format the jpeg to show on the projector that supposedly supports it
Open the image with ANY image editor on a computer (Paint will do just fine) and click "File -> Save As" choose filetype .jpeg and give it a new name. Whe this is done, try to load it again on the projector.
This way you just try to reformat the image in to the jpeg format. If this dose not work, your projector are probably not going to display jpegs at all.
If this still dose not work, you may want to consider formatting the device you put into the projector (If it is a usb, sd card or similar) to ensure it is clean, i suggest formatting to FAT32 as this is most commonly supported by peripheral devices. Aaaand try again ;)
Apr 11, 2016 | Cameras
I bought a used jazz ultratab c855 dose not have SD card tryed to use one I had here and it Won,t work do I need to buy a special card or can I format one to work ?
Your jazz ultratab c855 should work with SD up to 32 Gb; are you sure that the card you have is good ?
You can test it introducing it in a MicriSD Reader and check it in any computer. If shows up as Removable Drive with correct size, your card is good.
Jun 20, 2015 | Jazz Cameras
Memory card error
The GR-DF570 uses SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot it's electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
If you need a manual, you may download a copy here.
Sep 07, 2012 | JVC GR-DF570 DV Digital Camcorder
The memory card will not read
You may need to reload the drivers for the card reader. You can find that on the support site of your pc maker or you can use the install disc that came with your pc.
Good Luck
Dec 30, 2011 | HP Computers & Internet
Card is portected dose not record
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 18, 2011 | Sanyo Xacti C40 Camcorder
My camera flashes "note: if sd card is
After Note: , it should say internal memory must be erased in order to use the SD card. Yourn LCD is probably about to puke so you don\'t see the second line.
Have fun with the junk LCD replacement parts.
Sep 17, 2011 | Moultrie 6.0 Game Spy Infrared Camera...
New memory card dose not work. Keeps saying formatting. Its called SDHC memory card multi use.
Your problem is it's an SD"High Capacity" (SDHC). This type of card came out after camera was designed, and although it looks the same as a standard SD card, its not. Sorry, but there's no way to make that type of card work with your camera. But just go on Amazon, You can purchase a standard 2GB that will work with your camera for about $6 to $7 (total with shipping).
For others reading this with similar problems, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 25, 2011 | Kodak EasyShare Z760 Digital Camera
Dose the Lg 420 GM support a micro sd card
Unfortunately, it does not support the use of external devices.
Mar 25, 2011 | Cameras
Any internal backup memory??
The internal memory only works when no card is in the camera and then only holds a small number of pics. If you had the memory card in the camera most of the time, most of your pics were on the card.
Jul 07, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Photo transfer
change the pic format options in the camera to read *.jpeg intead of *.raw
if they are in jpeg maybe the computer dosn't understand the way the camera formated the sd card mine dose the same thing when i try to tranfer images from my aiptek dzo-v50 without the camra i just get card read error
Oct 21, 2008 | Cameras
Fuji FinePix S7000 Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
