Question about Cameras
X 20 dimage minolta
There is no image of any resolution on my blind camera
only a streak of light on a dark background
that is when i take a picture or when i see a picture on the camera
  • Cameras Master
  • 1,879 Answers
Greetings,
Let us hope that the only display controller or the LCD is malfunctioning, take a shot and try transferring the image to a computer (memory card or usb).
No matter what the result is, that camera is service bound.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 07, 2008
Minolta dimage 20, turns on but cannont take clear image
Hello
If this camera is a Minolta Dimage X20, then the problem is probably a faulty CCD, this may be repaired free of charge, I suggest you contact a Sony service center as they have taken over support for Minolta cameras.
Sep 26, 2008 | Cameras
My minolta dimage x20 does not show a picture or take one
CCD is bad, needs replacement. TEst to see if you can see recorded pictures. If not, then professional repair is needed.
Aug 02, 2008 | Fuji FinePix A360 Digital Camera
Horizontal lines across pictures
Probably a problem with the chip - this model had a recall and free fix...contact the manufacturer for details
Jul 24, 2008 | Konica Minolta DiMAGE X20 Digital Camera
My minolta dimage X20 whern turned on is all ready to take a picture but is only showin blackness, i can preview pictures etc and do every thing else My Minolta DiMAGE X20 is doing the same thing and has...
thats called "vigneting" and is caused by misalignment of the lens.... has it been dropped or mishandled? if so, it needs re calibrating and setting up by a pro camera technician.
Mar 04, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
DARK PICTURES
I am afraid the shutter is faulty, which means it does not get enough light from the image, however it will still print the image but not in natural light, battery is not an issue here, you can try changing new battery but i don't think the image will change, the bottom line is the camera is faulty and tell the seller for refund if possible.
Dec 01, 2007 | Konica Minolta DiMAGE X1 Digital Camera
This definitely sounds like a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Nov 16, 2007 | Konica Minolta DiMAGE X20 Digital Camera
Minolta Dimage S414 Problem with resulution
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
DIMAGE X20 Digital Camera
This sounds like a defective Sony CCD issue. If so, Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
May 01, 2007 | Konica Minolta DiMAGE X20 Digital Camera
Only see bright light effect in viewfinder and LCD
the Screen has failed or a connector to the main board has come lose. Check out the Makers help line for advice. The likely cost of a repair is going to be high be prepared for a new camera.
Oct 29, 2006 | Konica Minolta DiMAGE Z2 Digital Camera
NO IMAGES CAN BE SEEN THROUGH LENS????
its again a case of suspected bad CCD. the symptions you have mentioned indicates towards that your camera needs a new CCD.
Jun 21, 2006 | Konica Minolta DiMAGE X20 Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
