Question about Nixon Lodown Tide watch
How do I turn of the sound it makes every hour?
How do I turn off hourly chime?
Your watch could be defective but at the point where you turn off the hourly chime, check the face for a symbol that disappears.
Dec 18, 2015 | Puma Faas 200 Sport Watch
LGC310 mobile phone has a cuckoo chime every hour on the hour, how do I turn this off?
Press the "OK" button then "settings" then "date and time" then "time" then scroll down to "hour indication" and change this to off.
Feb 09, 2012 | Watches
I have a AW60448W stopwatch that I can't get the alarms to turn off.
AW60448W Stopwatch
Okay, now you have an excellent Stopwatch but don't know how to set it up. Well, I had the same problem but a friend of mine wanted one also and after I bought it for him, he being an old guy, could not read the small print that came with the Stopwatch. I have gone to the trouble of typing it up and you can benefit from this.
Now I don't expect you will send me any donation/money but if the mood strikes you, I will accept no more than $3.00 cash.
Ron Gray
9540 C.R. 13 North
St. Augustine, FL
32092-2602
E-Mail: NowPrinting@BellSouth.Net if you have questions.
Your Welcome
S1-Button: LAP/RESET
S2-Button: START/STOP
S3-Button: MODE
LIGHT BUTTON: Needs no explanation
LIGHT BUTTON:
The watch is equipped with an electroluminescence (EL) backlight, which can be activated by pressing the EL button. The LCD will light up for three (3) seconds.
CONTROL OF WATCHES:
Normal Display: Hour, Minute, Second and Day of week.
Push of S1-Button: Display shows alarm time in Hour and Minute.
Push of S2-Button: Month, Date and Day of week.
Push of S3-Button: For change of Function.
ALARM OF CHIME ON/OFF:
In normal time: Hold S1-Button and Display shows alarm time in Hour and Minute.
Hourly Chime: While holding S1-Button down, press S3-Button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
Alarm: While holding S1-Button down, press S2-Button. Alarm icon will display when alarm is on. Icon will disappear when alarm is off. Release S1-Button and Display changes to normal time immediately.
CHRONOGRAPH MODE:
In normal time, Push S3-Button, chronograph Function will be set.
Start/Stop: Push S2-Button, it operated in cumulative counting up to 1/100 second.
Split Time: Change to Split Time from chronograph time display is performed by pressing S1-Button while chronograph is counting.
Chronograph keeps counting while Split Time is displayed. Push S1-Button again to return to Chronograph Time display.
Reset: Push S2-Button to stop counting and then push S1-Button.
ALARM TIME SETTING:
In normal time, push S3-Button twice to get into Alarm Setting Mode. Monday flag + Hour digits will flash, which is advanced through depression of S2-Button.
1 x Push of S1-Button: Monday flag + Minute digits of the Alarm Time will flash, which is advanced as above.
Push of S3-Button: Display change to normal time again.
NORMAL TIME SETTING:
In normal time, push S3-Button three (3) times. Tuesday flag + second digits will flash. Push S2-Button and Second will be reset to zero (0).
1 x Push of S1-Button: Minute digits flash and advance by depression of S2-Button.
2 x Push of S1-Button: Hour digits flash and advance as above.
3 x Push of S1-Button: Date digits flash and advance as above.
4 x Push of S1-Button: Month digits flash and advance as above.
5 x Push of S1-Button: Flag of weekday flashes and advance as above.
Push of S1-Button and second will start for setting again.
If S3-Button is pushed during anytime change Normal Time will resume on display.
12/24 HOURS REVERSAL OPTION:
You have the possibility to change from 12 to 24 hour system, when adjusting the hours of the normal time (description please see above) one after the other the hours are displayed in the 12 hour system, then in the 24 hour system and then again the 12 hour system, i.e. please push S2-Button so many times, that the hour is displayed in the required system. In the 12 hour system hours are identified by "A" from 24:00-12:00 and with "P" for 12:00-24:00 whereas in the 24 hour system all hours are identified with "H".
ALARM TEST:
Hold S1-Button and then hold S2-Button together. Alarm will "Beep" and Alarm sounded.
ALARM SOUND OFF:
To turn off beeping when Alarm goes off press S1-Button or S2-Button.
For some model, press Light Button also can turn off beeping when Alarm goes off.
Alarm function with 4 to 5 minutes snooze by press S2-Button.
Lifetime Limited Warranty
The Geneva Watch Group warranties that it will repair any failure due to defects in material and/or workmanship free of charge. This warranty is by Geneva Watch Group, not by the dealer from whom it was purchased. This limited warranty does not cover replacement of crystal, battery, band, strap or case. Geneva Watch Group reserves the right to replace any and all inside components in lieu of repair. This warranty does not cover any failure to function properly due to misuse such as water immersion or sever shock. If your watch ever needs service, wrap it carefully in tissue paper or a similar soft material and pack it in a mailing carton. Send it via insured Parcel Post to:
47440 Michigan Ave.
Suite 130
Canton, Michigan 48188
U.S.A.
Include a brief note explaining what is wrong. Be sure to print your name and address clearly. Enclose $7.00 to cover the cost of return postage and handling.
"Do Not send cash or checks. Only Money Orders, Master Card or Visa are accepted."
Card Holder Name: _________________________________________
M. C. ___________Visa______________________________________
Account Number: ___________________________________________
Expiration Date: _____________________________________________
visit us at www.advantagegroupinc.com
AG9936-00
To set Time:
1) Press "MODE" button until Time is displayed.
2) Press and hold "LAP/RESET" button until seconds display starts flashing.
3) Press "START/STOP" button to change selected entry.
4) Press "MODE" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "LAP/RESET" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "LAP/RESET" button until minutes display starts flashing.
4) Press "MODE" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "LAP/RESET" once you are done to set the alarm.
To toggle Alarm Sounds ON and OFF:
1) Press "MODE" button until ALM is displayed
2) Press "START/STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "START/STOP" button on the watch.
How do I turn off the hourly chime on a Wal-Mart Athletic Works stopwatch?
The way to do it is push the "light" button, then the "set" button. If the hourly chime is active, the days indicators will all be highlighted, if it's disabled, they will be turned off too. Basically it's the same as turning the alarm on/off, but instead of using the "start/stop" button, you use the "set button".
Dec 28, 2010 | Watches
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
Cannot turn off beap sound after every hour
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all PULSAR watch manuals. Rate me, please
Mar 15, 2010 | Pulsar PF3293 Wrist Watch
How do I trun of the change of hour chime on my son's tghk watch
Press the bottom right button and while holding it down press the bottom left. All the days will show and the hourly chime is off, if the days aren't lit the hourly chime is off.
Sep 11, 2009 | Watches
How do i make my watch beep by the hour
Press and hold SET, then press START/STOP. This should turn the chime on. Press it again to turn on the alarm.
Dec 27, 2008 | Timex 1440 Nylon watch
Casio Illuminator
I used the online CASIO web site to locate the appropriate manual and followed directions. Use the bottom left (C) button of the watch to keep pressing between the various modes until I was in the ALARM Mode. Then PRESS the upper right (B) button to toggle the DAILY ALARM and HOURLY CHIME to "OFF", "DAILY", "HOURLY" and "BOTH" on/off.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1950.pdf
http://support.casio.com/manual.php?rgn=1&cid=002
Jan 17, 2008 | Casio W94HF-3AV Wrist Watch
Nixon Lodown Tide watch Logo
317 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
