Question about Hotpoint Dryers
Dryer is noisy - Hotpoint Dryers
  • jeff britton Dec 28, 2010
    What kinda noise?
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
The dryer is making a knocking sound when running. The sound has increased lately. What may be the cause of the noise?
Hello there and thank you for choosing fixya
If your dryer is noisy, check these:
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to repla
Aug 04, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Noisy vibration when drying
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. Here is a video of the testing and replacing dryer drum rollers this will walk you thru the troubleshooting and replacement of these parts. Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
Oct 19, 2010 | Kenmore 63942 Dryer
My whirlpool awz 7303 is very noisy. i think it is something to do with the drum going round. could the belt need tightening?
If your dryer is noisy, check these: Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing assembly does not fail often in this type of dryer. There are videos of the testing and replacing of these parts at http://appliancehelponline.com/dryerrollervideo.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there. All parts come with installation instructions. Not all models are available.
Sep 13, 2010 | Whirlpool AWZ7303 Electric Dryer
Dryer is noisy especiallly after start up.
Jun 01, 2010 | Whirlpool LEQ9030P Dryer
Dryer noisy while running overloaded yesterday
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 09, 2010 | Whirlpool ET8CHEXSQ Dryer
Noisy Frigidaire Electric Dryer
Here is a tip that I wrote that will give you somethings to check out...
heatman101
Apr 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Affinity front loader dryer. The drum is not
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. Hope this helps
Dec 10, 2009 | Dryers
Dryer makes a squeaking noise
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore stackable washer/dryer...dryer making HORRIBLE shrieking sound while drying...any ideas?  don't have dryer #
Hi
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 84052 Dryer
Noisy dryer
check to see if its level and let me know what kind of noise and age of drier
Nov 04, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
48 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
