Question about Acer Aspire 5520-5908 Notebook
How do i refofmat my hardrive - Acer Aspire 5520-5908 Notebook
    Problem Solver:
  • 5 Answers
The unit either came with a set of CDs that have the re-installation tools on it and that will do it OR there may be a partition on the hard drive that has these files and tools on it and you either have to make your CDs or run the tools from the utility partition. Be sure to not wipe this partition when you reformat or you will lose this.
Posted on Dec 28, 2010
  • Acer Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Tip
Hardrive Failure
When ever you get a hardrive failure message or Beeps coming out of your computer it is best to go ahead and replace your hardrive because it is most likley corrupted
on Jul 15, 2010 | Computers & Internet
Will not boot up
Ive done a few dell mini notebooks and this problem was always corrupt hardrive or the hardrive died. Solution take hardrive out plug it as external into another pc see if it spins up and you see it show up on pc. If it does then itll be just corrupted and will need windows reinstalling. If it doesn't youll need another hardrive itll be dead. There not expensive depending on what size you wanting. Hope this helped.
Feb 19, 2012 | Dell (INSPIRION MINI 10) Netbook
Xbox 360 stops loading (freazes) a saved game at dif. pts.s of same save?
your hardrive mite be sorupt or damaged. see if it dose te same on another consel with te same game. olug ur hard drive into another consel nd play the game till itts saves see if it still freezes. if it doesnt the its your consel. mite be having some problems wit data transfer to your hardrive. if it still freezes its either te game or your hardrive. clean the game wit some scratch remover. sometimes scratches cant be seen but will still efect the gameplay. if it still freezes then its your hardrive. you mite wana try getting a new hardrive
Dec 14, 2009 | Microsoft Xbox 360 Console
How can you tell if your hardrive is damage? i have a toshiba satellite m50 laptop. I also want to know if the hardrive is calculated in percentage. I took my laptop to get it repaired and i was told that...
try using the basic utilities that are on the computer. disk clean up and scan disk. Scan **** should give you the info on how bad your hard drive really is. And yes any electrical connections installed improperly could cause harm.
Nov 30, 2008 | Toshiba Computers & Internet
I would like diagram on hooking hard drive to hard drive.
If you are trying to put another hardrive into your existing pc I could explain but you if would like something more visual then there is a tutorial here
its simple really since the computer auto detects the new hardrive. the hardest part are the jumpers on the back of the hardrive. You see one hardrive has to be set to Master and the other has to be set to slave. the hardrives can connect to the IDE cable (the big flat cable inside your pc) in any order but they cannot be both set to master. The jumpers are easy to switch and the hardrive itself will have a diagram right next to the jumpers to show you how to move the jumpers to make the selection.
its a great idea to have two drives in your pc in case something happens to the first, but i always recommend a hard backup (cd/dvd).
Nov 13, 2008 | Computers & Internet
External Hardrive crashed
Try reading this post........http://forums.macosxhints.com/archive/index.php/t-32880.html
Jul 18, 2008 | Computers & Internet
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Acer Aspire 5520-5908 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
