Question about HTC Touch Cell Phone (Unlocked) - Soft Black
Touch pad not responding
Hi
my phone touch pad not responding. phone is working. i accidently lock the key pad also. i cant access the phone at all now. please help.
thank you,
prabu
  • 3 more comments
  • kunalupad Nov 17, 2008
    Exactly facing the same problem. Need help. SOS
    I have the same problem exactly. SOS
  • Anonymous Mar 01, 2009
    I have the exact problem
  • Anonymous Mar 03, 2009
    All of a sudden the touch screen of my HTC Touch has stopped responding all other buttons(red, green, navigation, camera, on/off and voice up n down) are working absolutely ok.
  • asugeet Mar 06, 2009
    touch panel is not working
    Problem Solver:
  • 6 Answers
Try resetting ur phone by holding the red and green buttons while hitting the reset button on the bottom with the stylus. All the information u have saved in ur phone will be lost but it will work afterwards.
Posted on Jul 15, 2008
Touch pad not working
Hi
Maybe you accidentally hit lock key of your touch pad. Just press FN key + F7 key (key logo for touch pad).
Or run the SYSTEM RESTORE, Go to START, Choose ACCESSORIES, choose SYSTEM TOOLS, choose SYSTEM RESTORE and then choose PREVIOUS RESTORE DATE that your touch pad is working fine. If not, use the other restore dates if necessary.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 26, 2011 | Computers & Internet
Touch pad is not working?
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
May 25, 2011 | NEC Versa FX Notebook
My phone is locked and i can not unlock it as the touch screen does not work.
Hi, What makes you not to have access to the phone is that the touch is bad that's why it's not responding. You will need to replaced the touch screen for you to be able to access the phone.
But before you replace, you can still loosen the phone and check if the touch pad has shifted from the position it was.
I would advice, if you can't loosen the phone,callfor assistance.
Take care.
Jun 15, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Can't unlock the screen
Hi, when a phone remains locked, it means that the touch screen (touch pad)of the phone you are using is bad will need to be replaced.
Replace the touch pad and you will start usingthe phone again.
Take care.
Jun 09, 2010 | HTC Touch HD Smartphone
The touch pad of HTC Touch responds intermittently.
hi, its a error in the phone, I had this happen to mine. You will most likely have to sent it away for repair. Just reflash the stock ROM and make sure that you have reflashed the stock SPL if you where using hard SPL and you will be ok this site will help you flash: http://lievenvw.wordpress.com/2008/09/18/howto-flash-your-htc-diamond-or-htc-touch-pro-with-a-custom-rom/ thank you
vijay
(vote for me)
Sep 23, 2009 | HTC Touch P3450 Smartphone
Iphone has a problem
Hi Bob. If your touch screen is fully functional on other areas or pages, I would restore the firmware. Should take care of that prob. If it is not responding at all, then you would probably be looking at replacing your digitizer.
Jan 29, 2009 | Apple iPhone Smartphone
Certain numbers on the hand held set do not respond when pressed. The nubers are 9 and, sometimes, 3 on the touch pad of the hand held. Why is this and how can I fix it? Thank you so much for any help you...
Sounds Like The Key Pad Backings Are Dirty This Happens With Time. You Can Fix It By Taking The Phone Apart And Accessing The Rubber Pad Behind The Numbers. Clean The Black Circles On The Rubber Pad With Rubbing Alcohol And A Q-tip Also Clean The Receiving End Of The Black Rubber Side Also Known As The Circuit Board. There Are Half Inch Or So Circles On The Circuit Board, Clean Them Off Using A Q-tip And Rubbing Alcohol As Well.
Please Note: Remove The Battery Before Attempting This And Find Any Screws That Are Holding The Device Together. After That Get A Small Flat Head Screwdriver And Work It Between The Gap Along The Entire Edge Of The Phone ( Starting With The Mouth Piece Is The Easiest) Please Take Extra Care Not To Break The Phone If You Still Cant Seem To Get It Apart Please Check Again For More Screws.
Jan 09, 2009 | AT&T 650530003417 Cordless Phone
Garmin nuvi 350
You can recalibrate the touch pad. It's in one of the setup menus I think.
Nov 19, 2007 | Apple iPhone 3G
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
280 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
