Question about Intel Motherboard
945m/b SIR, IAM USING INTEL 945 MOTHERBORD, BUT NOW A DAYS IT AUTOMATICALY RESTART MY SYSTEM, WHEN I OPEN ONE PROGRAMME ONE SECOUNG HAND AND RESTART THE SYSTM. SO GIVE THE SOLULION FOR THESE PROBLEM. IAM USING 1 GB RAM 120 GB hdd ECT...
  • 63 Answers
Very little info for me to go on there, try running a full virus scan with an up to date product and a full antispyware scan with Spybot from
http://www.safer-networking.org/it/download/index.html.
Look in the logs to see what causes the restart with xp:
How to View Event Details loadTOCNode(2, 'moreinformation'); To view the details of an event, follow these steps: 1. Click Start, and then click Control Panel. Click Performance and Maintenance, then click Administrative Tools, and then double-click Computer Management. Or, open the MMC containing the Event Viewer snap-in. 2. In the console tree, expand Event Viewer, and then click the log that contains the event that you want to view. 3. In the details pane, double-click the event that you want to view.
The Event Properties dialog box containing header information and a description of the event is displayed.
That is taken from the ms knowledge base.
Post what causing the restart if you need further help.
Posted on Jul 07, 2008
    Master:
  • 788 Answers
A restarting system is tricky to diagnose. But it's usually can be broken down into two categories.
Software: If any of your device drivers are corrupted or missing this can restart your system. If you get a blue screen with a lot of white writting momentarily before it restarts then there should be an entry in the event viewer in the management console that may provide some insight. Right click on My Computer and go to Manage, you will see even viewer on the left. Skim though it and read any errors. Otherwise the best thing to do to rule out software as your problem is to reformat and reinstall Windows fresh.
Hardware: This can usually be attributed to the power circuitry in your system. If your power supply has been weakened or the power rectifier circuitry on your motherboard isn't functioning properly then this can cause reboots. I recomend removing any extra hardware that is not needed, for example remove any network card, sound cards, usb devices, printers, extra memory, CD drives, then add them back one at a time. You will either determine the faulty device or verify that your problem is either motherboard or power supply related. It's nearly impossible to rule out the power supply or motherboard unless you have a spare known good power supply to test with. You should also examine your motherboard for any bulging or leaking capacitors.
I cant install my zebronics geb 945 motherbord lan driver on windows7. plz help me
hello... this is your MB?
http://downloadmirror.intel.com/15117/eng/D945GCCR_ProductGuide02_English.pdf
Then the LAN chip is the 10/100 Mb/s) LAN subsystem using the Intel® 82562G Platform LAN Connect (PLC) device....
Then the SEVEN driver are located here....
https://downloadcenter.intel.com/product/76951/Intel-82562-Fast-Ethernet-Controller
Good luck...
Jun 14, 2014 | Intel Motherboard, 945GC, Core 2 Duo,...
Sir iam using mercury mother pi945gcm motherboard with intel chipset i want drivers
You may download the drivers from www.downloadcenter.intel.com
Checked his exact link
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Desktop+Chipsets&ProductProduct=Intel%C2%AE+945+Express+Chipset+Family&ProdId=2115&LineId=127&FamilyId=40
Sep 25, 2010 | Computers & Internet
Audio drivers
just install the audio drivers correctly and then go to contol panel and look for sounds and audio devices , open that and configure correctly .. and also check this ... go to start/run and type msconfig ..in that go to startup tab , there u select he option enable all , then apply and restart your computer...your problem will be solved....
Jul 04, 2009 | Microsoft Windows XP Professional
Intel 845gvsr motherbord nos display.
with no ram you will get beeps that confirms your processor is working (as it cant detect ram) you could be using the wrong speed or type, also as Ghoaliass stated, if your using a couple of modules try one at a time, if it fails on the first, remove the stick and try anther one and so on until you at lease get a bios screen :)
Hop-e this helps,
XBM
Nov 26, 2008 | Computers & Internet
Can u assist me, i hav motherboard but there s no name in that how can i find it, the only thing i found in the board is 945-15D2
it is 945 chipset using intel chips or may be made by intel but it will use the drivers of 945 chipset
Nov 19, 2008 | Intel D945GCL Motherboard
Not Installing Intel D945GCNL drivers for windows 2003 sp2 server
The first thing you need to do is load the chipset drivers for the 945 chipset which is an executable file provided by Intel.com ~Steve Medley
Nov 05, 2008 | Microsoft Windows Server Standard 2003 for...
NEEDED INTEL 945 GTP AUDIO DRIVER
What operating do you have.need to know to help you or you can try this sight
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2064&lang=eng
just enter the operating system in and find the audio drivers.
Oct 20, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Hd audio driver fail
i have intel 945 motherboard when i install audio driver i found error hd driver fail how can i resolve this problem.
Apr 09, 2008 | Intel Creative Labs Sound Blaster 16 PCI...
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
