Question about Panasonic PT-AE2000U Projector
I have a Panasonic PT-AE2000U. It will power up via the main breaker but then go straight into standby mode (red light). When I hit the power button the power light turns green and the screen turns on, but after a few seconds everything reverts back to standby (red light again). I have cleaned the unit inside thouroughly, cleaned the filter and replaced the bulb (I don't think it needed it, but I figured it couldn't hurt) and it works when I reseat everything but then after a few days the problem comes back. When the projecter works the fan sounds like a freight train, but when it starts its "standby mode" the fan makes no noise at all... Could a bad fan be the source of all this (and if so can I replace just the fan)? If it's not the fan, what else could it be?
Marrie
  • 563 Answers
SOURCE: Panny AE 700 Shut down
Done
Posted on Apr 15, 2008
SOURCE: Panasonic AE100U Keeps shutting off
I have exactly the same problem. I was told by Panasonic sales rep that a shipment of AE1000U projectors came in that have a faulty board (he thought optical board but wasn't sure). Only solution is to replace the faulty board.
Posted on Nov 08, 2008
  • 3 Answers
SOURCE: Panasonic PT-AX100U-EC
I just repaired mine with some oil for the iris assembly.
The problem is the iris is either slow to respond or doesn't respond to it's controller. The cam should snap back to it's resting point and move freely. It needs to be re-oiled. Mine would move but sluggishly like it was sticky. There are TWO pivot shafts to oil. One on top and one on the bottom. The bottom one can be accessed by removing the bulb. You can see the bottom cam while the bulb is installed. This is a good point to test the iris movement at.
You need to have some mechanical ability. If you don't think you can do this then don't.
First remove the bottom bulb cover. Now get a flashlight. Look in the area that bulb is pointing towards. In the left corner of the side towards the front of the unit where the lens is, you will see a brownish cam. It has a spring around it.
Take a small screwdriver and move it to it's extent like a wheel. Let go and it should quickly return to where it was. It virtually snaps back to it's resting point. Do this several times. 5-6 If at any time it returns sluggishly then it needs to be oiled. 3 in 1 oil works great.
This takes time. I used a small jewelers screw driver to deliver the oil. As you oil it move the cam back and forth to work the oil to the shaft. Standing the unit on edge after you put the oil in the gap helps the oil get to the shaft.
If it now starts to snap back put the bulb cover back on and try the unit. If after 5-6 movements it still does not snap back each time then the actual motor shaft needs to be oiled as well.
Take the top off. There are several screws and one on the back. All have an arrow marking them. The cover is caught around the lens assembly. You have to be a little bit violent to get it off. After the cover is removed, you have to really look for the upper iris cam. It is under the large multi pin connector with brown wires on the main main display board. There is a small perforated metal cover under this connector.
After bending the cover up you will see the linear motor that drives the iris. There is a small flex cable going to it. You need to oil it's shaft. Use the same procedure to oil it as the cam under the unit. After oiling this shaft the iris should now snap back to rest every time. That's it.
Posted on Jan 04, 2009
Motobias
  • 6 Answers
SOURCE: Faulty Panasonic Projector
90% that this is a bad psu !
had mine fixed today with used psu from ebay.
try to find a faulty pt-ae900 for a exchange psu !
60€ faulty projector + 60€ psu = 120€ for pt-ae900
hooray :)
cheers,
tobias
Posted on May 04, 2009
SOURCE: Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Posted on Nov 28, 2009
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
I have an panasonic pt-ae2000e projector, how do i get sound?
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
Mar 21, 2011 | Panasonic PT-AE2000U Projector
Panasonic PT-AE2000U All three HDMI Ports stoped working. I have tried different HDMI cable and a three different HDMI Feeds. I can get a picture using the red green blue component cable. Any ideas?
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
May 20, 2010 | Panasonic PT-AE2000U Projector
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
hooray :)
cheers,
tobias
Dec 31, 2008 | Panasonic PT-AE900U Multimedia Projector
RS 232 control
..did you ever solve this? i am trying to write some code to do the same thing with no luck at all. and the manual does not seem to help much besides letting me know that I have to use 'PON' and pad it with a start bit and an end bit. i find nothing online as well.
Dec 28, 2008 | Panasonic PT-AE2000U Projector
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic PT-AE2000U Projector Logo
315 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
