Question about Coleman Heating & Cooling
I have a coleman evcon electric furnace ,it was running and would not cutoff the heat got up to around 90 thhe thermostad said it was running in aux ,so I turn the main breaker off and the in a few minute I cut it back on it started running for a fewq seconds and it would cutoff the repeat the process so I cut it of again and the later turned it back on and now nothing happens and the aux light is still on and the core is warm but no heat comes out and the blower does run
  • Coleman Master
  • 8,220 Answers
If the thermostat is ok which it probably is then your sequencer is most likely stuck i would say. You could verify that by removing 24 volts to the sequencer to see if it will shut down the heater
I have a coleman evcon - themobilian_598.jpg When low voltage from the thermostat is applied at the base of this sequencer it heats a bi-metal and turns on each coil and fan in a sequence that will insure the breaker don't throw from the power surge AND warm air comes out the vents when that fan comes on. I would start there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 28, 2010
I have an Electric Furnace that blew the transformer and the reverse thermostat relay, Have replace them both and the Heat and fan sequence the side the marked M1, M2, M3 M4 showed signs of overheating that also has been replaced, but overall since the transformer and the other componets have been replaced the heating coils have not kicked and when the heating switch on the furnace it push the blower just wants to run continous
Posted on Jan 14, 2011
When i turn up the thermostat the furnance doesnt come on
have you replaced the board? Need more info. Have 120 volt power? check small fuse in board. Make sure blower door is closed, it has a cutoff switch.
Sep 29, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Evcon eb15b
thermostat, heat sequencer or contactor, no 240 volt power no 34 volt power
Nov 23, 2013 | Coleman Heating & Cooling
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
371 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
