Question about Pentair Minimax NT Heater
Why does the display show "HI" all the time?
  • 310 Answers
This means that either there is a bad high limit switch, or you are getting a bad burn, or the pump is not moving water fast enough. With the power off remove the panel on the side above the plumbing.
There will be a pressure switch seated right on top of the header, then right below that, there are 2 high limit switches (1" round disks) Most typically, the pressure switch will start to leak and currode the contacts of the high limit switch, but some investigating will be necessary.
Posted on Dec 29, 2010
Tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
on Feb 04, 2011 | HP Photosmart C6180 All-In-One InkJet...
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
It stopped working. One display reads "CH" and
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Mar 26, 2011 | Comfort-Aire BHD-501 Dehumidifier
Hoe to I get my hp 12c calculator to show the begin/end format? It did, now when o hit "g" "7" beg or "g" "*' end, can not get to display? Thank you !
Begin mode is obtained by pressing [g][7] and it should then show BEGIN in the bottom line of the display. End mode is obtained by pressing [g][8]. End mode does not not show an indicator in the display because it is the default mode, so if BEGIN isn't showing, then the calulator is in End mode.
Mar 18, 2011 | HP 12c Calculator
Hi - I just moved and when I hooked up my 2003 Panasonic SC-AK100, it stays in 'demo' mode and won't shut off completely...after showing "goodbye" and apparently shutting off, it comes back on...
http://www.retrevo.com/support/Panasonic-SC-AK100-manual/id/356ag917/t/2/
Page 12:
A demonstration of the display is shown if you have not set the clock.
You can reduce the power consumed in standby mode by turning it
off.
During standby mode
Hold down ['square icon'/-DEMO] until "NO DEMO" is displayed.
Every time you hold down the button:
NO DEMO (off)↔DEMO ON (on)
To show a demonstration of the display
Hold down ['square icon'/-DEMO] until "DEMO ON" is displayed.
Jan 16, 2011 | Panasonic SC-AK100 CD Shelf System
Hi there, I've just received a brand new Verbatim Insight 500GB portable harddrive, but I can't seem to get the screen on it to work. I've reformatted it using as NTSC with 64kb allcation as per the...
Hi! I had the same problem after disk was reformatted to NTFS. I tried find solution in Internet, but nothing not found. Then I reviewed one more time the instruction and found the following line: "The display feature is not supported under NTFS with partition type "GUID Partition Table (GPT)"." After I format disk to FAT32 back all works fine.
Jan 10, 2011 | Computers & Internet
Pentair Minimax NT Heater Logo
196 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
