Question about Canon PowerShot A480 Digital Camera
A friend bought a Canon A480 on my recommendation but she can't get the date/time to stay. She has to reset it every time she uses the camera. The user guide says to replace the date/time battery but this shouldn't be the problem in a new camera. Any ideas?
  • Canon Master
  • 4,738 Answers
If it's a new camera, and it is doing this, it is defective. Your friend might consider returning it for replacement. But before she does, one quick thing that she can check is to reseat the little clock battery that controls the date/time. The battery could well have gone bad. It's located in a little slot labeled CR1220 right next to the AA batteries in the battery compartment. Just use a fingernail to pry open this little compartment and remove and reinsert the little button battery. If that doesn't fix it, and if returning the camera is not an option, next consider purchasing a replacement CR1220 battery from your local drug store. It should only cost about $3.
Posted on Dec 28, 2010
  • madcrazyarti Dec 29, 2010
    She removed, cleaned and reinserted the date/time battery (after finding out that it had one!) and it seems to have fixed the problem. She did this before I received your message but I just wanted to let you and others know that this worked and it should definitely be tried first before buying a new battery or returning the camera. Thanks!
  • koschmar Jan 08, 2011
    Thanks! Had the same issue.
    What did we do before google?
I am unable to determine how to get my camera to put the date on the pictures. Cannon Power Shot A480. Pam
Press the FUNC/SET button. Use cursor-up/down to select the recording size (probably L, unless you've changed it). Use cursor-left/right to select the date stamp icon (clock on a picture). Press the MENU button. Use cursor-left/right to select [Date] or [Date&Time] and press FUNC/SET.
It's all in the "Inserting the Date and Time" section of the manual (page 56 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
Mar 09, 2011 | Canon PowerShot A480 Digital Camera
The date and time setting in my canon digital camera needs to be reset . How does one do it.
Press the MENU button. Use cursor-left/right to select Setup (wrench and hammer icon), use cursor-up/down to select [Date/Time], and press the FUNC/SET button. Use cursor-left/right to move between fields, cursor-up/down to change them. Press FUNC/SET when done.
Feb 06, 2011 | Canon PowerShot A480 Digital Camera
I want to switch off the date stamp in my pictures taken with A480, please.
Press Menu, scroll down to "Date stamp" and across to select off, date or date and time, then press menu again. The date stamp only works in Postcard mode, so if you set a different picture resolution, that will also stop the pictures being date stamped.
Dec 19, 2010 | Canon PowerShot A480 Digital Camera
How can I have remove the date from photographs taken with my Canon PowerShot A480?
check t he camera settings and it should have an option for date and time which you can disable. Other people like to have the date to keep track on when the pictures were taken. hope this helps
Nov 04, 2010 | Canon PowerShot A480 Digital Camera
Canon PowerShot A480 How do I get the Date/time stamp on photos ?
Follow the directions in the "Inserting the Date and Time" section of the manual (page 56 in my copy). If you need the manual, you can download one at
Oct 11, 2010 | Canon PowerShot A480 Digital Camera
How do I remove the date stamp from a Canon A480??
Aug 30, 2010 | Canon PowerShot A480 Digital Camera
I have a canon a480 adn want to picture to actually say the date it was taken. Is that possible
Yes. Follow the directions in the "Inserting the Date and Time" section of the manual (page 56 in my copy). If you need the manual, you can download one at
May 21, 2010 | Canon PowerShot A480 Digital Camera
How do i get the sate to show on photos on a canonpowershot a480
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Mar 10, 2010 | Canon PowerShot A480 Digital Camera
Cant remove date stamp from pictures
1) push menu button 2) select tools tab 3) select date and time 4) use < > arrows to select options one of wich should be no dispay of date and time 5) push menu button to save choice
Sep 22, 2009 | Canon PowerShot A480 Digital Camera
Canon PowerShot A480 Digital Camera Logo
166 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
