Question about KLH R7000 Receiver
I simply want to connect only a left and right speaker to a KLH R7000 receiver. Which terminals are used if only two speakers (left and right) are connected?
    Brigadier General:
  • 8,546 Answers
Front Left and Front Right.
Posted on Dec 29, 2010
Manual for KLH R7000 receiver
Try Googling (KLH)(R7000)(manual) without parens.
Apr 23, 2017 | KLH Audio Players & Recorders
It has power but it clicks off
First thing to check is theat there is no shorts in your speaker cabling either damaged cabling or ends toching together at the amp or speaker connections.
If there is notheing tounching, try unplugginging ALL of the speaker wires then start it up again, if it doesn't click off then carefully check all of your speaker connections. try plugging them in one at a time while turning it on and seeing if it clicks off.
If it isn't a problem you might have a problem in the power supply or amplifier modules of your reciever - That problem would be one for the pros!
Hope this helps!
Good Luck!
Jan 17, 2010 | KLH R7000 Receiver
Klh audio video R5100 surround sound receiver
could be 2 things....
1) The receiver could be set to feed the right speaker with more volume. Check the volume setting for each individual speaker on the receiver.
2) The cable connecting the left input from your dvd player is not connected properly or is bad. Try swapping the left and right audio input cables to see if this moves the problem to the other side. If it does - get a new cable.
May 12, 2009 | KLH R5100 Receiver
Hitachi SR-2000 receiver's right speaker connection does not work
The SR-2000 has fuses for both left and right outputs. Make sure neither are blown. Otherwise this receiver has a STK 463 integrated chip that controls the output for both channels. When replacing the STK-463 it is also acceptable to use STK-465.
Jan 10, 2009 | KLH R3100 Receiver
Audio receiver!
When I watch movies, most of the talking is directed to the center speaker. During surround sound, this gives a more realistic environment, with voices coming from the source (center where your tv is) and ambeint noise coming from the left/right corners.
Get a small center speaker to solve your problem.
Jul 20, 2008 | KLH R7000 Receiver
Klh r7000 no sound
Like I wrote, I had a similar problem with popping and then no audio for an extended period of time. I found the solution on another site, http://dexsoft.com/blog/?p=15
Apparently the solder joints are weak, and just as the blog described when I opened up the receiver I saw the same scorch marks from overheating. Just as the blog described, I added solder to each of the joints in the photo and have had no problem ever since.
I am no solder expert, this is my 2nd time, but all I did is build up each of the joints and I have been listening to music, playing movies in surround sound with no problems, no popping for the last 2 weeks.
Jun 15, 2008 | KLH R7000 Receiver
KLH R7000 "popping"
what input u on were pops dish ? cheak audio out settings on dish box to pcm or uusing digital cable then use dobly digital
Feb 09, 2008 | KLH R7000 Receiver
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Klh r7000 no sound
go to this site dexsoft.com/blog. Is under : KLH R7000 no audio repair. Problem solve
Oct 14, 2007 | KLH R3100 Receiver
Buzzing in KLH R7000
look on the component for details or in the schematic of the device if u can find a voltage requlator that matches the same specifications as in ur system then u will b happy till then u will need the manufacturer requlator good luck windman
Nov 27, 2005 | KLH R7000 Receiver
KLH R7000 Receiver Logo
203 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
