Question about HP Photosmart C6180 All-In-One InkJet Printer
The feeder on top of printer does not feed the document--it makes a grinding noise. --The flat bed printer works. Please help me.
  • HP Master
  • 4,338 Answers
Open the ADF cover, Clean / rub the rollers with a damp cloth and a dab of dish detergent.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 28, 2010
Please insert your originals into the automatic document feeder
Try holding the table top lid down gently while you feed it into the document feeder. It may be that it is not reading the top as closed to defer to the feeder.
Jan 02, 2012 | HP LaserJet 3055 All-In-One Printer
How can I print from the top of my brother printer
Hi
You cannot print from the top feed,
The use of the top paper feeder is the capability to make single or multiple photocopies and for single scanning or multiple scanning. All you have to do is to put single or multiple document in the top feeder and press the COPY BUTTON (third button-right side). Then it will feeds automatically.
The same with scanning, press the SCAN BUTTON (first button-left side) and it will scan single or multiple document.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | Brother MFC-8460N Laser Printer
Have a Samsung SCX-5315F All-In-One that has a line running down the page when you copy using the document input tray. Clean copy when using the flatbed. I have cleaned all the glass thoroughly.
It sounds like it is dirty where it feeds through and not on the flat bed glass. Try and gently lift up the top section where the paper feeds through. If it resists you may need to locate clips or screws but generally the thin strip of glass under the top feeder is easily accessible. Good Luck
Feb 18, 2010 | Samsung SCX-5315F All-In-One Laser Printer
Will not feed original to copy from top insert level. Will copy if original is placed under, laid flat .
your feed tires for the document feeder are probaly needing replaceing. turn off mach and make sure document feeder plug is secure.
Dec 31, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Top feeder not feeding paper through
I have had this problem before and found that certain types of papers cause this. Can you try some different paper you may have lying around and try that? Post back with the results.
May 30, 2009 | HP Photosmart C7280 Laser Printer
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
ADF not working
Open the document feeder and look for an obstruction.
Clean the roller and pad with isopropyl alcohol.
Also look for a switch actuator trapped down or knocked off.
Dec 20, 2008 | Brother MFC-8840D All-In-One Laser Printer
Hp 2840 laser printer
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there.
Nov 12, 2008 | HP LaserJet 2840 Printer
MFC8840D
Hinge broken left, replace 25 bucks precision roller sells them as does any brother printer dealer, yes you can fix it yourself 3 screws, no manual required
Dec 23, 2007 | Brother MFC-8840D All-In-One Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
