Question about Dryers
My Kenmore Elite HE4 Electric Dryer is not starting. When I press the start button I get 3 quick beeps as if I made a mistake in settings. Reading other similar posts here I have done the following; cleaned it all out inside plus the vent. Tested the thermal sensor (white skinny ling thing) and it read 0 ohms. Right next to it is another sensor that read something in the middle so not open. It is diamond shaped in its mount to the pipe and has a tab like thing that sticks down into the vent. Repaiclinic.com has a part that it looks like it is a thermistor assembly. The belt is good and if I turn the drum I see the blower turn as well. I pushed the door switch and it feels like it is properly functioning but could not get the light to light or not, replaced light as it was original but still nothing nor can I get it to start no matter however I press the door switch. All I get is the 3 beeps after I press start. The control panel seems to work just fine unlike several other posts where people are having moisture problems. Any ideas will be most helpful I will try right away and will be most thankful to try something that will avoid a major service call days after Christmas. Thanks in advanced.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Sounds like the door switch is bad. Push the rubber grey plunger at the top of the door opening in and release. If it does not click, it is bad. You should be able to feel and hear it clicking. A new door switch is available at https://www.appliancezone.com/SearchProducts.aspx?id=8577274
Posted on Dec 29, 2010
Testimonial: "That was the answer!!!! THANKS!"
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4. Have same issue of dryer giving two
check your door switch take it off. if you have a meter check continuity when button is pressed you should have continuity. if you dont try tapping on it with a screw driver and putting it back together. let me know if this helps
Jan 05, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Beeping start button
possible stuck button on inter face ,, this sounds like kenmore oasis dryer
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE4 dryer 3 rapid beeps when pressing start button
the machine is in lock mode made for children in mind so that they do not touch any cycle while on,, look for lock icon hold 3 seconds and u will hear beep and that its it u r done ,,,,
Oct 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
