Question about SpeakerCraft BassX-10 Subwoofer
Hello, I have the speakercraft Bassx-10 subwoofer and it stopped working. I checked teh power cable, the cables going and coming from the woofewr and the surround system and all seems con nected th right way. It was working for several months when I first hooked it up but has no stopped. The only thing I can think of is the fuse is bad. I checked the fuse, it looks good but I will replace it as soon as I can find a replacement. Can you help? Thank you
2 Suggested Answers
zoomiezz
  • 50 Answers
SOURCE: Blowing fuse
I once rigged and old audio vox 8 inch sub into a box for a 12 inch cerwin vega had the same issue i just stepped the fuse from a 15amp to a 35amp had no problems after that.-z (you could also just solder the two wires for the fuse holder together if you have them eliminate the fuse or put a bigger fuse in).-z
Posted on Feb 21, 2009
My speakercraft BassX-10 speaker gets awfully hot, is this normal
check the max wattage for the speaker, should be on a plate or label. If your amp is supplying more than the speakers rated input? you could be slow roasting your speaker to death.
Jul 04, 2014 | SpeakerCraft BassX-10 Subwoofer
BassX
Thats a tough one. They no longer have the part and they are custom made for that product. best bet is to find a junk one w good transformer to use
Dec 09, 2013 | SpeakerCraft BassX-10 Subwoofer
Which color connection at sub woofer (white or red. RCA ) should connect to the receiver ?
Either one will work. You should get a rca "y" adaptor, at radio shack or another electronics retailer.
Mar 18, 2011 | SpeakerCraft BassX-10 Subwoofer
Need wiring diagram for bass w x 10
You have not mentioned what equipment you would like to connect to this active subwoofer.
Assuming you have an AV Receiver, you will require a single long RCA to RCA subwoofer cable. Connect the left input (white socket ) of the subwoofer to the AV Receiver subwoofer pre output.
Leave the front crossover knob at 100Hz , Phase at 0. While playing an audio track slowly increase the subwoofer front volume to suit your taste. If you are using big floor standing speakers along with the subwoofer reduce the crossover frequency to 70Hz. Phase should be adjusted to blend the front speakers with the sub.bobhifi_6.jpg
Mar 09, 2011 | SpeakerCraft BassX-10 Subwoofer
**** speakercraft!
Can you post the markings on the transistors themselves? I will look up what I can and try to get you a more common substitute. Post what eve information you can about the transistors and I'll see what I can find. The model and the output specs that are published for the unit would help too. Thanks, Dan
Jun 06, 2009 | SpeakerCraft BassX-10 Subwoofer
Blowing fuse
Feb 08, 2009 | SpeakerCraft BassX-10 Subwoofer
Sound controls
start by connecting speaker like the book-then you make setup for all your speaker and confirm that all in on status-check your cable for bad cable(short circuit-or open circuit)-you can insert the speaker one by one if you are in doubt that something wrong.
Jul 05, 2008 | SpeakerCraft Audio Players & Recorders
SpeakerCraft BassX-10 Subwoofer Logo
128 people viewed this question
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
James Oliver
Level 1 Expert
Electro Med Services...
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
