Question about Dell Inspiron 2650 Notebook
The resolutions become pixelize and distorted, I plug an external Monitor, same scenario that I have seen. Is it video card?
  • Dell Master
  • 4,338 Answers
Download the latest version from Dell. Uninstall the existing drivers and install the latest drivers from:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=INS_PNT_P4N_2650
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 28, 2010
Google earth says i don't have a graphics card
You may have an onboard graphics controller built into the motherboard and not a PCIe board physically connected to a slot dependent card. Google requires a High definition video processor to replicate Google Earth photos. The resolution needs to be approximately 1600 Pixels x 1200 Pixels or greater. You can get an inexpensive Color Card from TigerDirect.Com, plug it into the slot on the motherboard and attach your monitor to it. If you can get HD resolution 1900 Pixels plus, the visuals are excellent.
Dec 25, 2013 | Systemax Venture HU30 (988177) PC Desktop
Tip
LAPTOP to TV Connection
Many people today want to connect their computer to a TV. Most HDTVs today have a VGA input for computer hookup. Most laptops also have a VGA output for external display. Using a male to male VGA cable, the computer can use a HDTV for a display. Sound is connected using a 3.5mm audio cable. See this web page for complete details.
http://columbiaisa.50webs.com/laptop_to_tv.htm or this webpage
http://sites.google.com/site/columbiaisa/laptop_to_tv
The screen resolution setting determines how much information is displayed on the display screen. It is measured horizontally and vertically in pixels. At lower screen resolutions, such as 640 x 480, fewer items will fit on the screen, but they will be larger. At higher resolutions, such as 1600 x 1200, more items will fit on the screen but they will be smaller. The resolution options will vary with each computer based on the video card device, monitor size, and video & monitor drivers. If the screen looks distorted or fuzzy, then you may have an incorrect screen resolution size set for your monitor. In Windows you can change the screen resolution to match the TVs capabilities. Go here to view a video on how to change screen resolution:
http://windows.microsoft.com/en-US/windows7/Change-your-screen-resolution
on Aug 23, 2010 | Televison & Video
Cannot get the picture wide
Firstly you have not mentionrd thr Make & Model of your monitor.
Assuming it's a LCD Monitor you could try the following:
Modern monitors have a 'native resolution'. While most LCD monitors can display a wide variety of screen resolutions, the native resolution will always look best, since this is the screen resolution that matches the number of pixels inside the display. Any other screen resolution may look blocky or distorted, since the number of pixels used in the picture will not match the actual number in the display.
You can adjust your computers display resolution easily. For best results with your monitor, you should use the latest display drivers and monitor drivers and run your monitor in its native resolution. For more information on updating your display drivers, see this link.
Also have a look at this video
May 20, 2012 | Computers & Internet
How to increase resolution from 1024 x 576 pixels to 1280 x 600 pixels. I tried to change it by clicking start>control panel>display>settings but won't get desired results.
make sure wether the disply of your monitor and graphics card supports the resolution if the monitor doesnt support sthe resolution you will not be able to increase the resolution the mobilor becomes black
Sep 04, 2011 | HP Mini 1000 Netbook
My monitor is distorted. It is an E181H It is
Well, it has a maximum of 1024 × 768 @ 60Hz resolution. Double check that you have the correct Hz selected on your computer and that your computer video card supports the higher resolution. If the video card maxs out at 800 then the highest you can get is 800. If all your setting are correct and the video card is capable of using the settings you want then you may need to trade the monitor in or have it repaired. It should be under warranty being only 6 months old.
Jul 14, 2010 | E-Machines eMachines Monitor E15T4
There's a line drawn in the center of the monitor which suddenly appeared in my ViewSonic VA1703w monitor. I've restarted the pc and the monitor, but that line is still persistent. kindly suggest a...
If the line is there whatever the pc is it plugged in and whatever the resolution used then the problem is at the LCD panel itself - the command line on those pixels is inoperative. If you're lucky it will be just a loose connector to the LCD (open the case and reseat them all) if you're unlucky it will be in the panel itself - in which case the monitor is dead, this fault is unfixable.
Jun 18, 2010 | Computers & Internet
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
Flatron w2043s 20" there is distortion on all letters and numbers etc, its as if its ran out of ink ,spoils the picture big time
The distortion mostly is caused by a wrong screen resolution. Choose another (smaller or larger) resolution and once you've found the correct resolution for your display card tne distortion will be gone.
Aug 03, 2009 | Computers & Internet
Have a Emachine Laptop M6809 , the screen is all pixelated and distorted from bios boot through WinXP loading , same with external monitor .
Theres a problem with the video card of your laptop. If you just formatted your laptop, check if you have installed the driver of your video card. Or bring it to the service center if you still have a warranty for it.
Jul 03, 2009 | Toshiba Satellite A10-S129 Notebook
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
Dell Inspiron 2650 Notebook Logo
26 people viewed this question
Alun Cox
