Question about DIGITECH VOCALIST LIVE 2
I was using my digitech vocalist live 2 pedal during a gig 3 days ago and about 2 songs in, everytime i touched any part of the pedal or pressed the harmony on/off switch to activate the harmonys, the selected harmonies i had pre-chosen kept changing. Have had the pedal for 18 months and its the 1st time ive had a problem. Any ideas??
After using my digitech vocalist live 2 pedal, the next time I used it only the harmony side of it is working. The harmony on/off switch to deactivate the harmonys just switch the selected harmonies on the effects side works as well.The open mike side is dead. Any ideas??
Posted on Sep 15, 2011
  • DIGITECH Master
  • 5,603 Answers
Yeah I have an idea... It is likely static electric discharge. At this time of the year we get zapped touching metal things and it also drives electronics nuts... You don't even have to feel it to get zapped.
Try using in your bare feet and see if it fusses... We had a lady vocalist wearing those ugg boots and caused static pops in her microphone... anyway try the test and if it fixes the problem, then look up Staticide spray... You can get it at Amazon.com for example... spray floor in the area you are playing on to kill the static.
The only other thing is to check if wiggling the power input plug causes the problem. Those plugs are notorious for poor connections when they wear.
Posted on Dec 28, 2010
Can i run Vocalist live 3 through only an amp? if so how what cables do i need.?
The only guitar amp that has 2 female jacks, one xlr and one 1/4" is a tall Acoustisonic anp by Fender . I have one and I use the Vocalist 3 and I still have an instrument jack for my acoustic guitar . hope this helps .
Sep 18, 2012 | Digi-Tech Digitech Vocalist Live 4...
The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
Jun 21, 2012 | DIGITECH VOCALIST LIVE 2
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
Hi i have a vocalist live 3.. my harmony button..when i press it, it does not stay on. can someone please help me. it worked earlier but not now, i am not sure if i pressed somehting
To the guy with the vocalist live 3. You need to change the FS (footswitch) setting under setup. It toggles between a true switch and working only when you hold it down.
Nov 22, 2010 | Digi-Tech Digitech Vocalist Live 4...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
All the LED's come on and it does nothing
Have you seen this:http://www.digitech.com/products/Vocalist/Flash_Demo/VocalistLive2_Tutorial.php
Oct 15, 2009 | DIGITECH VOCALIST LIVE 2
After a few minutes of use, there is clipping and sound cutting out with the guitar through. Vocal and harmony are fine. I tried using different guitar cords, different guitars, different amps to no avail....
I know you hate this answer, but it needs to be repaired. It has a circuit board inside, and there's really not a work-around. But it is broken. I totally understand about not wanting to send your gear out, especially if it's a pedal board you have set just right, and are completely usweed to using. You'll be a lot happier with it if you get it fixed though. Or find another one on eBay. I sold all me Digitech pedals when I got my Pod - but that's just me, I use a lot of distortions and it fit the bill better for me. I used Digitech pedals for about 20 years and thought I would hate anything else.
Take care.
Mark
Jun 05, 2009 | Digi-Tech Digitech Vocalist Live 4...
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
DIGITECH VOCALIST LIVE 2 Logo
330 people viewed this question
Top DIGITECH Music Experts
steve cannon
Level 1 Expert
noel
noel
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
