Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My problem is similar to the one above. My opener with lift the door, but when it comes to a stop in the "up" position the lights blinks and there is a clicking sound and I can't get the door down unless I hold the garage button down.
    President:
  • 3,197 Answers
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Posted on Dec 29, 2010
How do you remove the oven door from a Maytag MGR 5780 range. I cannot see any latches on the hinges
There aren't any latches on the Maytag MGR5780 oven door hinges. You should be able to open the door to the first stop (about 4" from the closed position). Then grab the sides of the door and lift the door up at that same angle until the door clears both hinge arms. Manage My Life has the manual for the MGR5780 here: http://www.managemylife.com/mmh/owner_manuals/25316/MAYTAG-Free-Standing,-Gas-L0303326 . See page 15 (16 of the PDF) for a picture of the door open to the first stop position. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Oct 23, 2013 | Maytag Heating & Cooling
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
MY LIFT MASTER 1245 IS HUMMING AND GARAGE DOOR STOP HALF WAY DOWN LIGHT BLINKS
If the main light is blinking 10 times check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Jan 31, 2011 | Sears Craftsman LiftMaster Chamberlain...
Dome light, which is actually above the back seat, will not light in the "door" setting. It does work, (both bulbs lit), in the "on" position. Help--my wife is on me about this!!!
if this is a problem with just one door, then go buy a door switch from a dealer. take the old one out and put the new one in. they either screw or snap in, cheap and easy. the light should come on with at each/ both front doors open. if it is a problem not coming on with all doors open, then you are going to have to do some wiring troubleshooting not a simple matter.
Dec 28, 2010 | 2004 Kia Sorento
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster garage door only opens 8 inches and then stops
It sounds like the opener is stopping because the weight of the door is tripping the lift sensor on the opener. There are two screws on the side of the opener to adjust the lift and close pressure. Find the lift pressure screw and ajust it higher to see if that remedies the problem.
Also, because you said the door will not stay open at the top when you open it manually, I think your springs are not adjusted correctly. They should hold the door open in the up position when not connected to the door opener. That may be the reason the opener lift pressure is kicking it out.
If you have to adjust the springs, be careful that you know what you are doing. There is a lot of potential for getting hurt if you don't know the proper proceedure.
Good luck.
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Lift-Master garage door opener stopped working
The motor will probably need rewinding.
Professional job. Don't forget to take the condensor with the motor.
Or alternatively, if money isn't a problem,, get somebody out to look at it.
There ya go:)
Jul 27, 2009 | liftmaster Chamberlain Garage Door Opener...
Have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
Apr 05, 2009 | Chamberlain 950CB Remote Control
Garage Door Opener Light does not come on when it is supposed to
Great call Marty! I had noticed the amber LED above the learn button was blinking with one pulse, which the troubleshooting guide noted as being a problem with the sensors. Finding that one tiny paragraph in the manual and following the instructions of holding the wall-control light button in for 10 seconds reprogrammed it and the functionality is returned. Thanks!
Jan 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
