Question about Cameras
Film broke of and is stuck in the film guide where I can't get at it...
  • yadayada
    yadayada Dec 28, 2010
    The film broke in a Digital Camera? I need the make the model of the FILM camera you have please.
  • 747 Answers
You are in the digital solutions asking about a film camera. I might be able to help if I knew the make and model of the camera you have.
Posted on Dec 28, 2010
Film stuck in on right hand side
First, be sure you've pushed the film release button (usually located on the bottom of older film cameras) and then try rewinding. If the film is stuck on the take-up reel of your camera your best bet is to manually unwind the film from the reel and see if it will work properly again. If not then it wasn't a film problem but a mechanical one on the reel.
Feb 15, 2014 | Canon Photography
Film advance lever stuck
Do you have a film in the camera? If so is it all exposed? Best thing to do is press the film rewind button and try the lever at the same time - this will eliminate stuck film issues as it removes film tension from the system. If this does not solve the issue then you need someone to have a closer look.
Feb 07, 2014 | Canon F1-N 35mm SLR Camera
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Jan 10, 2013 | Sewing Machines
Film roll stuck in my camera canon eos lx
The Canon EOS is a digital line of cameras from what I can tell. If that is the case, then there is no film in the camera.
However, assuming that you actually have a 35mm camera with film stuck in it, the following should work for. You don't indicate what you mean by stuck, but the standard solution for removing 35mm film from a camera is to take the camera into a dark room, open the back of the camera and remove the film and canister, being careful to not tear the film. While still in the dark room, place the film into a light proof bag to avoid spoiling it when it goes into the light. You can then contact a local photo processor about their ability to process the loose film. Make sure that the bag is clearly marked to avoid having someone open it by accident, spoiling the film in the light. If you can't find someone locally who can process the film, Kodak can do it for you in Rochester, New York. Contact them for instructions on shipping the film.
If you don't care about the film or pictures it may contain, feel free to simply open the camera and remove the cansiter and film, discard it, and start over.
Nov 14, 2010 | Canon Photography
Lost film guids for canoscan 9900f. looking for
lost film guids for canoscan 9900f. looking for 35mm strips and slides 120 and 4"x5" format film holders in the accessory kit for canoscan 9900f
Apr 07, 2010 | Canon CanoScan 9900F Flatbed Scanner
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Latch for the Film door broke
This is so tedious a job that I would not try it myself unless I was adept in doing this right.Unless the camera costs a lot to start with, I would just get another SLR. I believe the cost in repairing it depending on model and the size, will be about $200. I say this because from experience, I had a $250 camera 20 years ago and the latch broke on mine and he said it would not be worth it to fix it. Unfortunately, it was way out of warranty.
Jan 16, 2009 | Nikon F80 35mm Film Camera
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Olympus is-50
It sounds like the rewind button on the bottom might be stuck. Refer to page 10 of the user guide and check it with a pencil tip to make sure its not stuck in the pressed position
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
