Question about Waterway Above Ground Hi Flo Pump
In order to get the propeller to spin when first turning it on, have you kick start with a flat head screwdriver...then pump works perfect. What do I need to do so that when the pump is turned on, it starts without a twist of the flat head?
  • akaflaca1999 Dec 29, 2010
    Gosh, what a bummer. Unfortunately all the pool professionals in my area have gone out of business. I will look into the capacitor. Thank you!
    Problem Solver:
  • 16 Answers
Sounds like it needs a new capacitor. I would consult with a local pool professional. If you happen to be in the Phoenix Metro area you can contact me at info@wefixuglypools.com.
Posted on Dec 28, 2010
WASHING MACHINE DOES NOT TAKE IN WATER
Strictly for troubleshooting: check the inlet water hoses (where the two hoses connect to the machine) screens. Any interuption in water service can send screen clogging debris through your pipes. If screens are really covered clean them i.e. use a toothbrush, swish in a cup of water, turn the water on a teeny-tiny bit (keep your hands on that hose if using the last method.) Then try the washer. If screens only have signs of debris collecting then move-on that's not the problem. Although now is the perfect time to dig out the old gasket/washer and replace it. Garden hose washers work fine. Don't remove the screen to clean it. Don't crossthread when putting it back. Do not overtighten.
You didn't give a mod # so only assuming you have front loader that you can clean filter on (maytag, kenmore, whirlpool?) When you remove the filter can you turn the drain pump propeller with a finger? It should turn like an airplane prop, but easily. Does it feel straight when it turns. The stem of the propeller can distort and kick it off center. If that pump goes out it plays havoc with the whole works.
Also not sure about symptoms. Are you saying it works fine sometimes but occasionally acts-up? Dianosis is difficult without more info. Specifically Mod # and history of symptoms. Sorry.
Dec 08, 2012 | Washing Machines
I have an error E20 showing on my machine. The filter is ok. How can I check the pump for a blockage ?
TURN POWER OFF FIRST take the kick plate off undo the screws holding pump to machine lean the machine back so you can get underneath it a torch will be handy then you need to take the screws out of the pump pull pump of filter and undo hoses clear any blockages then check the propeller on the pump if it falls off or spins around freely you need a new pump. it should as you spin it round lock into its place kind of thing as you move it round.
Jan 05, 2011 | Zanussi IZ12 Front Load Washer
Suds or blocked pump
Hi
To access the drain pump, remove the front of the machine. Remove the kick panel at the front bottom of the machine. The 2 screws need just 1 turn to loosen, use a flat head screwdriver. There are a couple of hidden clips on the Kick panel that secure it to the machine. These are located at the top edges of the Kick panel, and can be pressed on (by sliding a wide, flat knife between the top of the Kick panel) to release the Kick panel from the front of the machine. Now you’ll be able to see the screw cap for the drain pump, it is located on the left hand side. Before removing this cap make sure that you have a container and lots of towels to clean the water as there is a risk of flooding the floor with water. Clean the pump and your issue will be resolved now. please post back for more information. Hope this helps...
Daniel
Aug 30, 2010 | Bosch Washing Machines
How to replace water pump on a 1985 90 hp mariner outboard motor
mcdevito75 Here, If I;m not mistaken the water pump is in the lower houseing, a big job, let the marina take care of it as the water pump should be Changed only if it doesn"t pump at all.
Jun 16, 2010 | 2004 Mercury Mariner
The pump is not pushing water through. Wat is the
ure the propeller and shaft turn, but I woulsd dare to say that they are actually turning independant of each other. Sort of like a stripped nut on a bolt. They both look like they are in place and working, but when you add any sort of pressure they just don work the way that they are supposed to. I bet the shaft is actually spinning inside of the propeller, as soon as the water pressure is built up, it fails. Spinning it with your fingers will not imitate the real life pressures exerted on the propeller and shaft, that the water pressure exerts under load (in operation). I would either rebuild it with new parts (new shaft and Propeller) or just go out and buy a new one with a warranty. There is no other reason why this pump will jnot throw water through your system... NO REASON, unless you have the thing hooked up wrong, but I think that would be impossible, wouldn't it?
Apr 24, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Hot tub pump flo-master hp suddenly wont start. it' one year old and was working perfectly. air side started to make a squealing noise the night before. draining hot tub to check volute to make sure motor...
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 18, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
The washer has stopped emptying and spinning. The pump does not appear top be making any sounds either.It is a hotpoint aquarius
OK... Pessure switch is proberbly stopping the machine from spinning due to the water level in the machine... The pump could have just stopped working, or, the control board could be broken and therefore the pump not getting a supply current, or, the propeller in the pump could be jammed by debris.
1. Turn the machine off, and unplug...
2. Take the drain pipe and lower it to an outside door or other place to safely drain the water away that is still in the drum.
3. Follow the drain pipe till it reaches the pump. Check the lead to the pump to make sure it is properly engaged into its recess on the pump motor.
4. Take the hose off the pump in order to clear any debris and then replace the hose
5. Having done all that, plug the machine in and turn it on
6. Put it onto a spin programme ... The machine should now lock the door, then both pump and spin actions should start... If not, your control board or cabling is at fault
Aug 20, 2009 | Hotpoint Washing Machines
My turntable starts in the middle of the record only after me helping it start spinning.
you need a flat key that slots in where the rubber grommit is on the turntable platform. Remove the rubber stopper, use a flat head screwdriver into the slot inside the hole, out an old record on the turntable, and try the play button to see where the arm now lands ( dont forget to put the stylus protector on to prevent needle damage! ) and then keep making small adjustments till the arm starts at the beginning of the record. I actually have an original sony flat key should you want it? but to be honest a long shaft screwdriver is perfectly adequate for the task? email me at lesliemurphy_964@msn.com if you want the key though?
Les Murphy
Aug 15, 2009 | Sony PS-LX250H Turntable
Motor hums, but propeller will not turn
I HAVE A ZOELLER PUMP AND THE IMPELLER WONT TURN I TAKE A SCREW DRIVER AND TURN IT AND IT WORKS STOP THE PUMP AND IT HUMS CAN THE IMPELLER COME OFF IF IT DOES HOW DO YOU TAKE IT OFF.
May 06, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Waterway Above Ground Hi Flo Pump Logo
201 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
