Question about HP DeskJet 810c InkJet Printer
Doesn't pick up the papaer to print - HP DeskJet 810c InkJet Printer
    Scholar:
  • 89 Answers
There are two possibilities that I can think of. One, there is something preventing the paper from being "picked" or two, the paper is not in the right location. Remove the paper and look for foreign objects or a paper wad stuck in the paper path. You might need a flashlight to see. Also the back panel is removable to get a better look.
Check that the paper is inserted all the way into the paper tray and that the paper tray is inserted fully into the printer. The 8.5 x 11 paper should be about one inch from the forward edge of the tray and the tray should be within about 1.5 inches of the upper tray's forward edge. The side stops should be within an 1/8 of an inch of the side walls on the printer's chute.
If the printer has been used a lot, the pinch rollers might be worn out, but that would be unusual.
Posted on Mar 16, 2011
How can i fix my HP Deskjet F4280 printer, it wont pick paper for printing
Uninstall the printer, delete drivers, look if new drivers are available for it and reintall the printer.
If problem continues my guess is that your printer is defective.
Printers are made of chep plastic materials and after some use parts get worn out and break down. HP has a so called repair kit available for repair service. If your printer won't pick papaer, quite probably some of these partss is damaged. If you don't know how to repair printers aand dont have access to parts, take it to a repair service.
Oct 12, 2015 | HP DeskJet F4280 All In One Printer InkJet
Bother printer mfc 430cw
rollers inserted incorrectly, sensor broken or bent, or drive grear broke.
Feb 28, 2014 | Office Equipment & Supplies
Papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
Apr 02, 2012 | Toshiba Office Equipment & Supplies
When i give comand printer do not load paper
try to clean papaer pick up roller whit wet cloth or alcohol.
Open front door
remove toner cartridge
clean blue (usualy) paper pick up roller inside
Aug 19, 2010 | HP LaserJet 1300 Printer
Will not accept photo papaer
It means that it will not support oil or photo paper...i think it will support A4 or smaller only
Jul 05, 2009 | Brother MFC-465CN InkJet Printer
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
HP670C DESKJET PRINTER
Dear Sir.
Kindly see that you have used Genuine Cartridges.
RegardsRafique
Mar 28, 2008 | HP DeskJet 670c InkJet Printer
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
HP DeskJet 810c InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
