Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I think its stuck on bolt, motor runs then light blincks and shuts off
    President:
  • 3,197 Answers
If the main light is blinking 10 times it is a door sensor problem. Make sure the door sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Posted on Dec 29, 2010
How do you remove the driver side seat to replace the power seat motor? the seat is stuck al the way forward. the motor runs but the screws do not turn.
Hi William:
Usually the seats are attached to the floor by four bolts.
Removal is a matter of opening the door,
put something soft on the ground to protect your knees
With a flashlight, look under the seat to locate the bolts.
With a socket or combination wrench, remove the bolts
unplug any electrical connections,
PRESTO!
Out comes the seat.
Sep 08, 2015 | 2006 Pontiac Grand Prix
YORK PROPANE 90% FURNACE, Ventor motor runs when furnace turns off, Think switch is stuck closed but need part number
That is all on a circuit board. But I think your furnace is shutting off because of a high limit situation. (they run the vent motor if this happens.)check the filter-don't use a hepa filter. also if the A-coil is dirty it can cause the same prob.
Jan 30, 2015 | Heating & Cooling
IR SS5L5 Won't reach shut off pressure
It sounds as though your unloader valve is stuck or broken. I would try and repair it but otherwise you will have to bite the bullet and get a new switch assembly I think. As you have just been working on the tank it might just be a bit of debris dislodged and stuck in the unloader valve. The unloader should only hiss just after switch off weather by automatic shut off or by manual shut down.
Jun 05, 2010 | Ingersoll Rand SS5L5 Ir Electric...
2002 Turbo 1.8 Jetta gas door stuck
When you get the door open leave it open and open and shut the locks see if its catching the sides any where i think theses are all individual electric motors that open each door the motor that runs this lock may have had it or possibly rusted you could xdisconect it and try cleaning it wd40 ect i think you access it in the boot by removing boot lining probably 1 nut and a wire harness or take the lock off all together the rest of the doors shoukd still work even with this motor off hopevthis helps cheers ivan
Jul 04, 2017 | 2002 Volkswagen Jetta TDI
Transport shuts down after exactly 4 secs. Aslo stuck on Dolby c. Belts etc are fine.
Main motor is weak and running slow pulse to counter is thinking and telling logic board to stop . motor needs rebuilding
Oct 09, 2009 | Pioneer Audio Players & Recorders
Antenna motor runs while the radio is on or off. The antenna is stuck in the extended position. When the car is shut off the antenna motor continues to run to retract the antenna, but it doesn't go
You need to pull the fuse for the antenna or just unplug it. It has a fairly ridgid plastic wire that pushes the antenna up and down. Works fine until the wire breaks then it rolls up (antenna down) but it never increases resistance because the antenna never comes down , it's like a fishing reel when the lure breaks off, so the motor thinks that the antenna is still coming down and it will run and run and run trying to do it's job. Your lucky it stuck up and not down. If you want your antenna to go up and down again you'll have to buy and install a new one.
Jun 02, 2009 | 1992 Jeep Cherokee Limited
Kenmore dryer 70 Series doesn't shut off, timer continues to run
there are 2 different kinds of units made back then.
one has a push to start button that could have a stuck contact causing the unit to think you are pushing the button and want it to run again.
the other could have a stuck motor switch and thats not available separately. you would have to replace the motor. try to clean any lint out of the motor if you have that type. use compressed air to blow the lint out of the motor. it usually works to get the lint out and it can cause the switch to stick.
Dec 28, 2008 | Kenmore 63942 Dryer
No image, lamp light blincking red
I have a 3 yr old AE900U dont know exact hours but prob at least 2000 hrs. about every other start up, the projector would flash little box; (replace lamp now). now a month later lamp wont come on. So this is prob the normal way a lamp will die. anything else might be another problem.
Jul 23, 2008 | Panasonic PT-AE900U Multimedia Projector
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
