Question about Nintendo Wii Console
My brother brought wii from US and once we set everything and powered it on there was a big sound and then the console does not power up
The power adapter could have blown up ... in US we use 120V and most of the other countries use 230V. Check if the adapter says it works with 230V .. if not, that would the first thing to check (get it from a friend to try it out)
Posted on Dec 28, 2010
Can i use my wii i brought in england in usa
I believe England uses a PAL system as USA / Canada uses NTSC. You'd have to set your Wii settings to compensate. Also, power outlets in England are different from outlets in North America. You'd also need a new power adapter.
Jan 05, 2011 | Nintendo Wii Console
Tip
Everything is plugged in but your Wii won't turn on
Okay so you have everything plugged in, but all of a sudden your Wii won't turn on, right? Maybe there was a power outage or your circuit breaker was flipped, or maybe nothing happened, but the fact remains that it won't work and you don't know why.
There is a decent chance that your Wii's power cable needs to be reset.
To reset the power cable you need to:
1) Unplug the power cable from the Wii and the wall.
2) Let it sit and rest for 10-15 minutes.
3) Plug everything back in.
4) Turn on your Wii.
It should work at this point if that is the problem.
It may sound silly but Nintendo built in the reset mechanism due to power cable failures and it often is the resolution to a Wii not turning on.
on Dec 22, 2009 | Nintendo Wii Console
My wii console won't turn on
Sounds like it overloaded the Wiis power supply when the power went back on. You should call Nintendo to try and have it looked at under warranty. How old is your Wii? Did you have a surge protector plugged in at the time?
Apr 01, 2010 | Nintendo Wii Console
Nintendo wii
The power block may have failed. I would try to find a replacement on ebay. First i would to try to contact somebody with a wii console and try there powerblock to determine if it is the power block or the console itself. Good Luck.
Dec 01, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Wii won't power up
Leave the wii power brick unplugged from the wall socket for 15 min then try to plug it back in. This worked for me.
Jun 11, 2009 | Nintendo Wii Console
Wii completely stops working after power outage
I just had the same problem as everyone else. I had a brief power loss and our new Wii system's power would no longer work. To fix the problem, I unplugged everything from our Wii and unplugged the power cord from the outlet. I let the system set for 10 minutes and re-plugged the power only. That did the trick. Then I was able to plug everything back up and we are now back to playing.
Supposedly, doing the steps above resets the Wii according to the Nintendo online trouble shooting guide.
Sep 28, 2008 | Nintendo Wii Console
Wii wont turn on
unplug from the wall and try it again, if still doesn't try some one else's power supply
Jan 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
