Question about Maytag Dryers
We have a Maytag Dependable Care Plus Heavy Duty dryer that starting making a grinding noise and smelling like it was burning. My husband is taking it apart to see if maybe there is something caught in the belt or if the belt needs to be replaced. If it has to be replaced then is this a hard thing to do? Any pointers?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Sounds like one of the roller bearings is going out. What is the model number of your dryer?
Posted on Dec 28, 2010
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
I have a Maytag Dependable Care Quiet Plus II Heavy Duty dryer. The vent fan is loose on the shaft. What needs to be done to fix it?
Must replace it cause there is a flat side on the shaft and the blower wheel matches up to it and rounded out the plastic. Take off front panel and take out the screws around the wheel to get the metal plate out of the way then it either screws on or has a snap ring and a clamp to take off now wiggle the wheel to slide it off. Install new wheel and put back together.
Apr 06, 2011 | Maytag PYE2300AY Electric Dryer
I have a Maytag Dependable Care Plus/Heavy Duty dryer (LDE8704ACE) that has served me well with no problems for more than 16 years. Yesterday, it started making a thumping noise that sounded like a huge...
hi look at the lower bottom of front there are 2 screws pull from bottom hing out watch for door switch wires swing front around. look in side top left and right corners 2 5/16 or 3/8 bolts pull them out. lift top up you will see screws that hold fin. oh turn power off hope this helps jim
Oct 13, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Dependable Care Plus/Heavy Duty Dryer Model # LDG9304AAM Dryer is turning, there is heat but clothes are not drying
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Sep 24, 2010 | Maytag Dryers
Dryer is making a grinding noise when the drum turns
hi your belt is ready to give up take does it smell of burning if not it soon will take the name make and model to comet they will sort you another and they are very easy to replace you just open the back of your dryer make sure it is unpluged first take the old one off and just slide the new one straight on problem sorted
Apr 26, 2010 | Maytag SDG3606A Gas Dryer
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
322 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
