Question about Casio Waveceptor WVQ-201HA-7BVCF Watch
How do you reset the time on this watch? thanks!
I bought this watch in May of last year. For the last 3 months, every 2 to 3 weeks I have to reset the hand home position. Once that is done, I have to then reset the home city and time manually. What...
Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
Feb 05, 2014 | Casio G-Shock World Time Analog Digital...
I accidentaly reset time & date on my square arnette watch and i need help to set it
Thank you for contacting FixYa.
    Set Digital Watch
  1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
  2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
  3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
  4. Set Analog Watch
  5. Pull out the watch crown on the right side of your Arnette analog watch.
  6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
  7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
Best regards. Jewel
Sep 09, 2010 | Watches
My husband's watch keeps resetting to 1/1/05 Eastern time. I've reset it a few times and its good for a few days then back to 1/1/05 Eastern. We live in the West and it's 2010 (so he can look at his watch...
Hi,the problem is either from a weak battery or a mechanical fault in the engine of the watch,
i think you should replace the battery,if the problem persists afterwards,then it's time to give him a wrist watch as a birthday gift.
Be cool.
Jun 13, 2010 | Casio Waveceptor WVA104HA-1AV Wrist Watch
I have a Carne & Viceroy Radio Controlled Watch reset time
I went to How To Mend It Site and I fixed the watch in ten minutes and it was free I expected fast response from you because of the charge.
Dec 18, 2009 | Watches
Manual for Smash Brand Watch 05-0407
You need to reset your watch completely and to do that, you have to start from battery.
Extract watch battery completely and leave your watch without energy supply for an hour. This will erase any data kept in watch memory.
Then put the battery back in watch exactly the way it was and reset your watch using your manual.
Unfortunately I can't help with manual as the original is the best you can get.
Don't forget to rate, please.
Jan 14, 2009 | Bulova Watch
How do i set alarm on a gap sport watch?
For setting Time & Date...
1. Push "MODE" button three times (change Mode to TimeSet)
Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
2. Flashing Second Number Digits
3. Push "RESET" to select...
Second -> Minute -> Hour(12hr<->24hr) ->...
Date -> Month -> Day of Week -> Second -> ....(repeat)
4. Use "START" to set each item...
For setting Alarm ON/OFF
1. Push "RESET" button then Push "START" same time...
Alarm ON -> Alarm OFF -> ... (repeat)
Jan 09, 2009 | Columbia All Sport Digi Watch l
Blue angel watch resets to 4:00pm all the time after being set.
I think it is time your watch received a Citizen tune up. Start here ... http://www.citizenwatch.com/
Thanks for posting your question to FixYa.com
Please vote
thanks
a
Nov 19, 2008 | Citizen Blue Angels Skyhawk Watch
Resetting the time
.im looking for instructions on an Accurist watch model MB008 many thanks
Jan 05, 2008 | Watches
Alarm
You can press the four push buttons at same time to reset the watch and then set the time again, it will help you to solve the problem
Thanks
Tsai
Nov 05, 2007 | Freestyle Shark Buzz Wrist Watch
Casio Waveceptor WVQ-201HA-7BVCF Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
