Question about Whirlpool Calypso GVW9959K Top Load Washer
Mod: GVW9959KQ2 Control Panel is stuck reading 42 min. Normal button is depressed. I press other buttons but no response. I press start button and nothing. I disconnect from wall then reconnect and same thing. I have removed top console and reseated connections. It is a no go. The last few weeks, it just turns on by itself (the display reads 42 min). It will do this with lid closed or open. It keeps beeping on and off at different intervals. But I was able to use it. Now all buttons are not responsive.
  • 4,323 Answers
Hi
First try to jump the lid switch just to make sure that it is fine. If this won't solve the issue then the electronic control should be replaced as it is not responding and so the unit is unable to complete the cycle. The lid apparently seems to be fine but still check it before replacing the board. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 28, 2010
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Says to reset color ink tank. put a new one in and says same. reset many times nothing happens
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Feb 21, 2011 | Canon PIXMA iP90 Mobile Printer
THE FOLLOWING BUTTONS WERE DEPRESSED.......NORMAL WASH, HEATED DRY AND LOCK ON......ALL THESE BUTTONS HAVE A STEADY LITE.....THE START/RESUME BUTTON LITE IS FLASHING. IHAVE HELD THE START/RESUME BUTTON...
Hi
Press and hold the NORMAL WASH-HEATED DRY button simultaneously & repeat this sequence for 5 times...this will reset the control. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
My dryer when to begin to work stop and show E68 the dryer is gallery series thanks for help me
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Dryers
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
HP X4270 5 YEARS OLD. CONTROL PANEL READS HAXMNTE KHONKY B --NOT FAX,COPY,SCAN CONTROL PANEL DOES NOT RESPONSE TO BUTTONS. i UNINSTALLED AND THE SAME PROBLEM OCCURS WHEN I REINSTALLED WITH THE CD. NEW...
Step 1 Remove the power suppply from the back of the printer...
Step 2 press and hold the stop/clear button (the button with the red X)..
Step 3 Insrt the power supply into the back of the printer...keep holdin the button...
Step 4 The printer would display the language as english
Step 5 Select the desired settings
Vola ...ur printer should be back to normal...
Else contact on 1-800-332-4120
May 02, 2008 | Office Equipment & Supplies
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Whirlpool Calypso GVW9959K Top Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
