Question about LaCie (300728U) 250 GB Hard Drive
Broken pin on power supply kit. Is repair possible or is replacement required?
  • 11,800 Answers
You would need to find a new connector to replace the broken one - a very difficult task since they are not sold as parts. Just replace it and save yourself the hassle.
Posted on Dec 29, 2010
Which of the 3 shift forks operates 3rd gear? I need to replace it but cant figure out which one it is.
The Bike Technicians Tactic
Phase1
An electrical inspection on the bike should produce results. First, the bike battery powers the entire lightening systems mentionable as ignition, meter readings, head lamps, signal indicators. However, the battery provides the power supply to several entities though also significant is the fuse box containing circuit protection coils. Inserting the bike key into the ignition to perform start mode displays the capacity power circuits. A charged battery should display an indication in the meter reading area also known as bike dashboard grading. A malfunctioning start mode on inserting key in ignition may be traceable several locations on the electrical circuits. Attempting to repair the electrical power of the bike usually requires batter power power test kit. The test kit ascertains the battery power making possible progress to the remaining electrical circuits. Test kit also ascertains the fuse box circuit functionality either with fuses still intact or extracted allowing for the next progress level. An observation tour of the bikes electrical wiring kits from battery hold through fuse box compartments to each lightening display area either headlamps, indicators, and meter reading should produce results of any visible damages that may require repairs after the electrical inspection has been performed. Once any faults were observed on the electrical channels, repair mode is the next level. A dull battery either may have been depleted completely of durational capacity requiring another for replacement. Alternately, a depleted power supply due to prolonged storage may require charge functionalities. Usually, a device capacapble of restoring a battery of electrolytes is resorted for charger ability. The type of battery may require constuents either liquid cathode replenishment in the battery entrapment area prior to charging feature is assumed with electrolyte machine. Once the battery has regained full functionality makes way the next repair task. The fuse box may have simply required replacement fuses either as missing or burnt out. A fuse box usually contains additional spare for replacement functionalities. An alternate arrangement at acquiring fuses on the auto mart may replace the burnt devices. The next electrical task is wiring fixtures achievable by mending broken cords with appropriate electrician's tapes else malfunctions may remain. Alternately, a worn-out electrical wire is replaceable by acquiring the entire extension lengthwise between significant areas. The last remaining electrical units are lightening indicators consisting of bulbs or luminescent displays reflectors. Observe the blub areas either by loosening covers to inspect for observable burnouts else the entire electrical circuitry is ready for functionality observations with separate entities.
Engine Technicians Tactic
PHASE 2
A bike engine inspection includes observation for indications of malfunction. Any fluid residue is indication of problem areas. Where oil leaks usually requires engine block inspections. A bike engine consists of an entrapment compartment where mechanical combustion takes place. First, the entire observable block consists of an external coating known as engine bloc housing internal component of pistons, rings, and fastens known as cylinder heads. A bike engine has every component embedded within requiring technical expertise to achieve an inspection. Once deciding on the engine task requirements, acquire a tool box with the appropriate componements as first requirement before engine works is commence able. Second, the bike may require an area environment as workshop requirement to attain engine inspections. Third, bike engine are least bulky compared with vehicle engines however assistance would complement the inspection phase. Prior to inspecting the bike engine, a strap mechanism has to be assumed to achieve expert maneuverability also as safe precaution. Unless parts hinder maneuverability at engine locations, the only removable components should be the engine. First, start with disjointing the spark plug cables to acquire accessibility to plugs imbedded on the cylinder heads. The plugs require tools to loosen thereby exposing the combustible area. Once the spark plugs are exposed, two alternatives are likely. First, a spark plug may have gathered rust residue only requiring cleaning to attain regular capacity. The pin area of the spark plug may have been twisted due to overheating and slight melting dislocation. Usually cleaning the residue from old plugs may simply expose the ignitable capacities. However, an observation of twisted plug pin may require twisting back in place to achieve full ignitability once bike engine starts. A bike engine bloc has the pistons as combustibles or blasters of fuel gasoline. The rings perform as strap fasteners whenever the pistons move about combustibility. Usually, the engine entrapment components would have collected residue requiring clearing. Also, pistons together with rings may require replacements either as worn-out due to prolongs tasks or overexerted biker features.
Mar 05, 2011 | 1999 kawasaki ZX-6R Ninja
Fuel pump does not work if I try to start it , but if I send power to it with a power probe it turns.
Phase1
PHASE 2
Feb 25, 2011 | 2005 Suzuki GSX-R 1000
Is there a workshop manual available for the1984 honda cbx
Phase1
PHASE 2
Feb 25, 2011 | 1984 Honda CBX
Yahoo messenger does not show recent messeges
Phase1
PHASE 2
Feb 24, 2011 | Yahoo Messenger
No spark at all
Phase1
PHASE 2
Feb 24, 2011 | 2000 Yamaha YZF-R1
I am about to install a cam chain tensioner and do not know how to find top dead center. I have a 99 yamaha r1
Phase1
PHASE 2
Jan 23, 2011 | 1999 Yamaha YZF-R1
Got spark and batery they seem fine
Phase1
PHASE 2
Jan 21, 2011 | 1997 Suzuki TL 1000 S
How easy is it to repair a POWER FAILURE TO SONY KDL-32S3000 TV
Usually it takes a little knowledge of basic electronics and some soldering skills. If you have these, then it never hurts to try to fix it yourself. Its already not working. Just make sure to work safe, unplug before working on it and close up before turning on. If you think its a power supply you might be able to see some blown capacitors, or you might get lucky and find a blown fuse inside.
Hope this helps
Jan 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
HP Compaq nx7300. Pin has broken off from the power cord supply. Mains input cord now won't work as part of pin is possibly stuck inside. Took to original supplier who quoted £220 to replace entire...
absoloutly not!!!!! if the pin has broken in the external power cord and not inside the PC itself then all you have to do is replace the PSU ( power supply unit ) and the lead, this should cost you no more than £35 and its easy to replace yourself
Nov 18, 2008 | HP Computers & Internet
LaCie (300728U) 250 GB Hard Drive Logo
140 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
