Question about Dell Dimension 2400 PC Desktop
The DVD tray only opens after I push the button 3 or four times. When I press the button, the tray attempts to open but seems to be blocked. Finally, after several attempts, the tray will function normally, but I have to go through this procedure each time I use the DVD tray.
  • Dell Master
  • 11,800 Answers
The optical unit - it's tray mechanism to be more precise - has aged and it's starting to seize. Unfixable, you will have to replace it. Luckily a new dvd unit costs less than $30 and can be bought even at Walmart. Installing it is a 10 minute job that you can do yourself easily.
Posted on Dec 28, 2010
Dvd tray on MDR537H will not open
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Nov 22, 2013 | Magnavox Mdr537h Blk Dvd Hdd Recorder With...
Good evening. I have a Thomson DTH 5000 I am unable to retrieve a dvd from it as the drawer appears to be stuck!! any ideas as to how to sort out this problem. Many thanksja
Take the cover off the device, and look for anything blocking the DVD tray. If nothing can be seen, remove DVD by hand, and try manually pushing open the tray after pressing the open button.
CAUTION: Once the tray moves, get your fingers out of there FAST! The tray might not be able to cut you, but it will hurt like no other if your fingers get stuck in there!
Once the tray is open, push the open button a few times to open and close the tray. This will loosen any debris that may have blocked it. If it still won't move, then the motor has gone out or been disconnected. Have someone with experience working with electronic circuit boards take a look at it to determine the problem.
Hope that helps!
Feb 13, 2011 | Audio Players & Recorders
Just bought LG HT554 DVD Receiver, was told it was
This one worked for my HT lg 554:
Power On
Open the tray
Push 0 four times
Push Pause button
Though, I didnt do the last step, since the code edition appear before.
Mar 03, 2010 | LG Electronic LRA516 DVD Recorder
I was attempting to install program and now, the drawer will not open. I did the paperclip trick to no avail. It makes an attempt to open but the rod (?) seems to not be able to push the drawer open. ...
The "paperclip trick" should work - try doing it with the power to the PC off next time. You may have to angle the clip a little left, right up or down to find the point that needs to be pushed. Each time you pull out and push in the tray will move outward. - repeat as needed to remove the disk from the tray.
Power up the computer and gently push the tray in manually. It make not eject w/ the button or software command until the next power down / power up cycle, and then it should return to working as expected.
Oct 02, 2009 | Lite On LTC-48161H CD-RW/DVD-ROM Burner
The tray on my Phillips DVDR 3380 won't open. It says blocked or no disc. I have pressed open /close many times but to no avail.I have turned the power off, makes no difference. I have press stop when it...
I have the same problem. What I do is push my hand down firmly on top of the DVD Recorder above the tray and while doing this press the open button. If this doesn't work get a screwdriver and poke it into the sides of the tray and pull it away. I find that the first method works best! XD
Hope This Helps!
Jul 04, 2009 | Philips DVDR3380/05 DVD Recorder
Fix for DVD Player
Try making DVD player multiregion
region code solution as per
http://www.dvdcodes.net/newCodesAZ/codesD/DigixMedia/DigixMediaHT-1056A.php
Power up the player and open the tray. With the tray open, hit the setup button and then 0000 and then the "Up" button.
On the Setup menu, go to Version and hit enter. Go to region code and change the number to 0 for region free and hit setup again to save.
Or
Press the SETUP button. The setup menu appears.
Press ZERO on the remote control four times - 0000
Press the CHAPTER FORWARD button - the one on the bottom right of the remote control unit that looks like a double arrow with a bar.
A new menu item appears, "Version". There is a REGION option you can select, and this can be set to zero "0" for all regions. Once you see its set to region 0, press SETUP to exit, close the tray and power off. When you power up again, its region free. RCE disks work fine in this unit.
To recap - open the tray, press setup, press 0-0-0-0, press Chapter Forward, select Version, choose 0 for region free, press setup again.
Or
1) Turn on the System
2) Open the tray
3) Press "setup" button
4) Press four times the number "8": 8888
5) Press the "Next Chapter" button (>>|)
6) Appear a menu called "Setup Factory"
7) Select with the cursor movement key "Region All"
8) Press "setup" button to save de changes.
Aug 31, 2008 | Digix HT1056A DVD
DVD8723UK
this region code solution as per
Or
Or
2) Open the tray
Jul 11, 2008 | Digix HT1056A DVD
Disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Jan 12, 2008 | Microsoft Xbox 360 Console
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Dell Dimension 2400 PC Desktop Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
