Question about Lands Phones
Whilst decorating I removed the front panel from the white box, this left the wires hanging as they were not connected properly. There are 4 wires (green, white, orange and yellow) and 6 ports. Any idea which colour goes in which number port? This is only used for the internet.. Any advice would be welcome. Cheers Mark
    Sergeant:
    Champion:
  • 333 Answers
If you live in the UK, this is the normal wiring for a BT box
http://www.diydata.com/projects/telephone_socket/telephone_sockets.php
Posted on Jul 07, 2008
1990 gmc Sierra. The factory brake signal box My brake lights went out but all other lights work on rear end. There is a white wire hanging out from under dash that runs to brake control box. Where does...
depress the brake pedal whilst connecting a volt meter to this white wire , if you get power it's to do with the brake switch , if no power then just a spare wire dropped down and no need to worry any further about this wire , so if it did show power remove the brake switch/control box and see if it's obvious where the wire fits , get a workshop manual to help as these manual are invaluable with step by step guides ,etc
May 16, 2014 | Cars & Trucks
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
I am taking electricity from my home to my garage. I have a Q06-12L100s load center in the garage and want to know how to connect the wiresl. The ground is obvious. The white wire is connected to the big...
Here's a picture of a messy amateur installation:
Look closely and find the power feeder conductors entering the panel on the bottom. The white rises up to the right and terminates in the "neutral" bus lug on the top right. The black also rises up to the right and terminates in the left "line" bus lug on the left. The red wire rises up to the left and terminates in the "line" bus lug on the right - just below the neutral lug. Finally, the ground rises left and terminates in a separate ground bar that is secured directly to the back of the upper left side of the panel box in pre-tapped holes for this purpose.
Since you are supplying this panel from your home's panel, you MUST keep the neutral and ground feeders separated in this panel (even though they will both probably originate from the neutral bar in your home's service panel). You must NOT install the long "bond" screw through the neutral bar in to the panel box. If the long bond screw is already installed, you must REMOVE it (usually this screw it shipped loose in a bag with a tag on it).
When the picture was taken, the flash reflected back making the right side of the neutral bar difficult to see - so I can't determine if the screw is installed there or not. When connecting circuits to this panel, the hot wires will of course go to the circuit breaker terminals, but the neutral and ground wires must not be mixed. The ground wires (and ONLY the ground wires) must terminate in the ground bar. The neutral wires (and ONLY the neutral wires) must terminate in the neutral bus bar. The person that wired this panel has mixed them. This would be a dangerous situation if the the long bond screw mentioned above is installed in the neutral bar to bond it to the panel box.
I hope this helps and good luck. Please rate my reply. Thanks.
Jun 18, 2011 | Square D Co. QO612L100S Main Lug Load...
Loose wires.one white and one black at bottom of dishwasher
the black wire is the HOT wire ... it should be connected to 120 volts AC .. the white wire should be connected to the neutral/return wire (also white) ... the incoming AC line shoiuld also include a bare ground wire .. that should be attached to a green grounding screw ... if your machine is already hooked up then there should not be any wires hanging down not connected .. you may be able to see the incoming wire but it should be covered by the dishwasher panels .. all connnections should be made inside a metal box that should be provided under the machine and there should be a strain relief fitting that keeps the wire from pulling out of the box .. ..
Oct 06, 2009 | Dishwashers
On an LG 2277 washer. I try to start a load. I get error message: "de"- door not closed. It looks to me that there must a switch to sense if the door is closed. Where is this switch located and how do you...
The switch is behind the front panel - to remove it, unplug the machine and:
1. Open the panel where the drain filter is (lower left side of the front panel)
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right
The wire connecting the panel to the machine on the right leads to the switch and door lock mechanism
Apr 25, 2009 | LG WM-2277HW Front Load Washer
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
pls rate people arnt rating hope this helps
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
Radio installation
1995 Isuzu Rodeo Stereo Wiring Constant 12V+ Red/White Switched 12V+ Brown/White Ground Black Illumination Green/Red Dimmer n/a Antenna Right Front Front Speakers 4" Dash Left Front (+) Blue/Yellow Left Front (-) Yellow Right Front (+) Green/White Right Front (-) Gray/White Rear Speakers 4" Side Panels Left Rear (+) White Left Rear (-) Red/White Right Rear (+) Orange Right Rear (-) Black/Orange
Dec 30, 2008 | 1995 Isuzu Rodeo
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Lands Phones Logo
75 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
