Question about OTC Ball Joint Installer / Remover
How do I change the ball joints on my 2001 ford explorer sport?
  • 21 Answers
I suggest purchasing the manual or going to your local library to see if the have it
Posted on Dec 29, 2010
2001 sport trac doeslower control arm have to be replaced due to balljoint or just balljoint replaced.
just the ball joint
check -if the ball joint is riveted into the lower control arm, it will be necessary to grind the rivet heads then punch out the rivets
replacement ball joints should come with the bolts needed to replace the rivets
some lower control arms have the ball joints pressed in so it is necessary to press out the old ball joint then press in the new unit
Jun 09, 2015 | 2001 Ford Explorer Sport Trac
Clicking sound at front driver side suspension when going over bumps or decelerating
Check your ball joints and steering stabilizer bushings for wear. I hope this helps.
Jul 05, 2011 | 2001 Ford Explorer Sport Trac
2001 Explorer Sport 2WD, 4.0L Automatic. How to replace the drivers side UPPER BALL JOINT? Would this cause the brake rotor to drag on the caliper support aon turns, especially when turning in reverse?...
check the axle nut and the wheel bearing for play.the caliper bracket is mounted to the hub.the ball joint moves the top of the hub,but movement in the bearing is more likely the cause.
Jan 29, 2010 | Ford Explorer Sport Cars & Trucks
How to remove the upper ball joints on a 2001 Ford Explorer Sports track
You will need to jack up the vehicle and also support it by the lower control arms as well as the frame. Remove the front wheels and place them aside.unbolt the upper control arms.....and wedge a pickle fork between the upper balljoint and spindle to knock the upper balljoint loose. Then simply reinstall the new control arms....which have the balljoints in them already.install the balljoint nuts and cotter pins and then reinstall the wheels and lower truck back to the ground.Be sure to drive vehicle to an alignment shop asap so you do not start to eat up your tires. get back to me if you have any more questions...i'm here to help!!!!!
Nov 20, 2009 | 2001 Ford Explorer Sport Trac
support vehicle under A frame remove wheel. loosen nut on top of ball joint.seperate spindle assembly from ball joint w/ball joint seperating tool AKA pickle fork.remove nut.ball joint is riveted to lower A frame-chisel off or drill out rivets.install new ball joint w/nuts &bolts supplied with it
Sep 22, 2009 | 2001 Ford Explorer Sport
How do i change upper and lower ball joints on a 2002 explorer sport
the lower ball joints have to be pressed into the lower control arms.The upper ball joints are part of the upper control arm so the upper control arms have to be replaced
Jun 24, 2009 | 2002 Ford Explorer Sport
Front tires are leaning in at the top and out at the bottom causing major tire wear
You probably need ball joints, unless you have large aftermarket tires which means you only need an alignment.
Jul 25, 2008 | 2001 Ford Explorer Sport
OTC Ball Joint Installer / Remover Logo
49 people viewed this question
Top OTC Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an OTC Tool and Hardware - Other Expert? Answer questions, earn points and help others
