Question about GPS
Holden Cruze - Clock Issue Polaris GPS/Bluetooth/Reverse Camera Just bought a brand new Holden Cruze with in-dash Sat Nav/Bluetooth/Reverse Camera and clock setting on the unit is causing me grief. Sat Nav program is fine, estimated arrival time at destination is correct. However, time on main menu (and when turned off) keeps reverting to 3 hours prior. I thought it might be a time zone setting but I have changed the settings and to no avail. Please help.
jackboy
  • 2985 Answers
SOURCE: clock battery won't recharge
Change to Ni-Mah rechargeables at the highest capacity you can find. If still in trouble it will suggest the internal battery has died - and a replacement is a repair job which will be pricey if feasible So just live without that feature.
Posted on Aug 29, 2007
SOURCE: Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
Reference:
http://www.emersonelectronics.ca/emerson/en/category/list/694
or
http://www.emersonelectronics.ca/emerson/en/product/details/2361
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at http://www.fixya.com/support/t236208-daylight_savings_time_adjustment for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual http://www.emersonelectronics.ca/emerson/en/product/details/2383, pg 9, and this is their solution.)
Posted on Nov 08, 2007
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
  • 3 Answers
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Posted on Dec 21, 2009
HarryHarley
  • 343 Answers
SOURCE: my 260 is way off on time of arrival by many hours.
When was the last time you updated the GPS firmware?
Sounds like that is the problem.
Posted on Feb 24, 2010
I wish a free download for maps on my sat nav
Sat Nav - Free Downloads at CNET Download
download.cnet.com/s/sat-nav/
Download.comResults 1 - 10 of 1697 - sat nav free download - TV Remote Controller (ARM/XScale), Virus ... Includes detailed instructions, with maps and street view images of.
upgrade sat nav maps - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to update satnav maps
Dec 17, 2013 - How to update satnav maps: TomTom, Garmin and Navman charges ... purchasing, you are entitled to download it and update your device for free. ... when i bought my Garmin, there were roads both new and old that were not ...
MapFactor GPS Navigation Maps - Google Play
https://play.google.com/store/apps/details?id...mapfactor.navigator&hl...
Rating: 4.5 - ‎736,227 votes - ‎Free
Jan 05, 2016 | GPS
How do I convert my sat nav from europe to usa
Some Sat Navs can't convert, If it's bought & set to UK & Ireland maps, then you are stuck. 2nd thing , even if you can use Europe Maps on your Sat Nav, you still will be unable, to load USA maps.
Sat Nav not compatable, You will have to buy a NEW ONE.
Mar 07, 2015 | Garmin nuvi 255W GPS Receiver
I am having problems with the nx501e searching for GPS receivers but doesn't find anything
I suggest contacting the folks you bought the maps from. Or, the clarion factory site.
Apr 21, 2014 | Clarion NX501 In-Dash...
Holden cruze bluetooth
Muslim Alam
Your mobile softwar update
May 19, 2013 | Nokia 2760 Cellular Phone
How do i update my Binotone 430?
You should be able to find out how to correctly update it in the manual. You didn't specify exactly which 430 model you had, but here are the links to each of them. Hope this helps you out.
Binatone R430 Sat Nav GPS Manual
Binatone D430 Sat Nav GPS Manual
Binatone G430 Sat Nav GPS Manual
Binatone F430 Sat Nav GPS Manual
Binatone B430 Sat Nav GPS Manual
Feb 05, 2013 | GPS
Can i put sat nav on the htc f3188
Hello.
Sorry, but HTC F3188 doesn't have a GPS receiver built in. You can buy a GPS receiver that can connect with it via Bluetooth, but they cost only 10-15$ less than a small sat nav.
Regards, Achil.
Mar 09, 2011 | HTC F3188 Smartphone
Why is the bluetooth connection failing on my motorola gps tn30
If you are trying to find the sat-nav from your phone, you need too try the other way from your sat-nav too your phone and hopefully that should work, just make sure both devices have bluetooth enabled and data transfer enabled
May 06, 2010 | Tomtom Go 630 GPS Receiver
How can i use my nokia E51 to avoid the radar?
you need to add a Sat Nav system to your Nokia. GPS tracking will have speed camera update. You need to buy GPS software and bluetooth GPS receiver to connect to the phone. Here the equipment needed: Sat Nav Satnav Gps+software:2c:for Nokia E51 N85 N96
Holux M-241 Bluetooth GPS Receiver + Data Logger (1xAA Battery/MTK ...
Sep 22, 2009 | Nokia E51 Cellular Phone
I have just taken delivery of a mazda 5 sport nav and the I have the following issue
Oh! i had a problem with the cd-player too! just replace it! my friend have a greay Sony's cd-player on his Subaru B4.
Jun 14, 2008 | Mazda 929 Cars & Trucks
GPS Logo
241 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
