Question about Ricoh Aficio 3025P Black and White Copier
Paper tone when printing - Ricoh Aficio 3025P Black and White Copier
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Check that bottel is full or not empty
Posted on Jan 01, 2011
Hp fax machine does not picks up incoming fax calls automaticly
check your settings to ensure that it is set to automatically answer fax calls. Also ensure that if you have distinct ring tone service that you have that feature enable properly for the ring tone that denotes faxes.
Sep 06, 2014 | HP LaserJet Pro M127FN Laser Multifunction...
Why won't my printer print purple?
Your Cannon printer is not the problem. You will get different print color depending on the paper you are using, For example you will get different print result if you print on color paper than on white paper and a different print if you print on photo paper. Another alternative is to lighten the tone of your purple. I don't know what your objective is and what project you're working on but I hope this might help.
Apr 26, 2014 | Canon MG5150 AllInOne Printer
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
Dec 30, 2011 | Samsung Office Equipment & Supplies
Colour photos will print fine on plain paper but when you select 6x4 and HP premium paper the output is very odd, for instance the black penguins in Windows sample folder come out with turquise blue backs....
It is not at all unusual for colors to appear different when printing on differing paper types. Your problem would appear to be an over saturation effect which alters the purity of the color tones. I'd suggest that you refer to information found under the heading "Change the saturation, brightness, or color tone" found on page 58 of the online user manual for your printer which is found at the following link:
http://h10032.www1.hp.com/ctg/Manual/c01552104
Jan 20, 2018 | HP Photosmart C5380 All-In-One Laser...
No pink tone in skin tone
are you using genuine or compatible cartriges?
never use compatables for photos - keep them for documents etc
Nov 18, 2008 | Canon I900D InkJet Photo Printer
Posterization (orangeish) when printing skin tones
i would try useing cheper Premium paper the paper you are useing dose not like the ink ib your printer
Nov 06, 2008 | Epson Stylus Photo R2400 InkJet Printer
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Sepia tone
You need a photo editor program that supports tranformation into sepia.
The easiest free way is to download Picasa 2
(Google Photo Manager)
http://picasa.google.com/
Once loaded you can autoscan you computer for photos....
Its a great manager....
Select the photo
Select the Effects button
Select Sepia
and Print....That Easy...
Nov 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Help
try using different 12 pt stocks....they are many different kinds of paper
Oct 25, 2007 | Xante Ilumina Digital Color Press Printer
Ricoh Aficio 3025P Black and White Copier Logo
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
