I cant get my computer to install the driver for my external Hard Drive. When i plug it in the computer and click my way trough the setup this error message comes up every time, and I have to abort. if i tell it to continue anyway, the device does not even register when I plug it in again. The software you are installing for this hardware: USB Mass Storage Device has not passed Windows Logo testing to verify its compatibility with Windows XP. (Tell me why this testing is important.) Continuing your installation of this software may impair or destabilize the correct operating of your system either immediately or in the future. Microsoft strongly recommends that you stop this installation now and contact the hardware vendor for software that has passed Windows Logo testing. Continue Anyway or STOP Installation. What should I do to fix this problem?
  • graeme ian hunter Dec 28, 2010
    What OS are you using? If its Vista, try running it as an administrator
  • 125 Answers
SOURCE: cannot print any document after
Did you get the latest software from HP? Perhaps your install disk is an old version.
Try here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=vn&dlc=en&product=3177562&lang=en
for an updated install for xp.
Big download though...
Posted on Jun 01, 2008
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
yooperbud
  • 8637 Answers
SOURCE: Prblem
Just go and continue . This should not affect the installation or operation.
Normal 0
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Feb 02, 2009
yooperbud
  • 8637 Answers
SOURCE: a4 tech pc camera has not passed Window logo testing
Just continue as the software will still work.
Normal 0
A. Skype Setup:
B. Yahoo Setup:
SOURCE: External USB Disk is installed but not visible under Mu Computer
Go to manage, refresh, and then asign a letter to it.
--- tuljo
Posted on Apr 27, 2009
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
A blue and red flashing light and won't connect to computer
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
My computer doesn't recognize my external hard drive and I don't have the CD to install it again. What do I do?
Try the external hard-drive in another computer.
If that computer also refuses to recognize it, then there is something wrong with the external hard-drive.
Apr 03, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
Computer won't recongize my Maxtor one touch
If plugged in the first time, the external drive needs to be initialized from your computer. Here are the steps.
1. Plug in your external drive to your computer's usb port.
2. Right click your My Computer and choose Manage.
3. Click on the Disk Management from the left. The list of available drives will show on the right.
4. Right click on your External drive and select create partition (primary partition).
5. After that you now you need to format the hard drive. Choose quick format.
6. Right click again on the partition you've just created, now select "Format" and select NTFS.
7. Click Ok and follow the wizard as it will guide you until it is finished.
Hope this helps.
Nov 18, 2009 | Maxtor 160 GIGABYTE USB2.0 EXTERNAL...
My IBM Thinkpad T22 has one usb port, in the back, so I bought a Targus 4-port USB hub. My flashdrives work, even my 16GB FD does. But I plugged in my Western Digital 250GB external hard drive and the...
You need to reinstall your usb drivers.
For that first go to my computer property ->hardware -> device manager
then right click on usb drivers and uninstall all usb drivers 1 by 1.
Then restart computer then check .
If problem still remain then enter in bios setup then go to ide or advanced option then enable "Legacy 2.0" then save settings then restart .
soem times old computer not supports new usb high speed device .
Aug 08, 2009 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
SimpleTech PininFarina external hard drive - site to download drivers
the hard drive you have is plug n play.
if windows does not recognize it, you may have to uninstall the hard drive.
right click your computer. click properties.
click on the "Hardware" tab. Click on "Device Manager".
open the category of "Disk Drives".
If you see your drive with a yellow exclamation point or a red "X", continue. If it does not, either it was dropped or its a faulty drive.
Right click your drive and click "Unistall". Click OK.
Now, unplug the drive and plug it in again.
it will install by itself.
Go to my computer and check that its there. If its not, you may have a bad drive. either send it for a new one (if still in warranty) or replace it.
Aug 12, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Toshiba 2.0 external hard drive
mrtunink,
Yellow ! simbol show in the usb devices means your usb driver may be corrupt so OS can't recognised the usb devices, u have to reinstall the driver like that way,
At first right click on my computer icon- then select propertices- then "hardware" - then click on devices manager buttons- then select ur devices and right click on it and click propertices then u finds reinstalls button under its propertices click on it and select install software automatically (recomanded) and click on ok. then windows scarch its driver automatically and install it.
Jul 02, 2008 | Toshiba 120GB USB 2.0 Portable External...
Can not find the device when i plug the usb into my pc
You need to used Disk Management, goto Start> Control Panel> Administrative Tools> Computer Management> Disk Management. Select volume/drive, if you found drive doesn't yet assign a drive letter, you need to assigned it by right click at the highlighted drive then assign drive letter then apply.
Finally, you will just use double click or right click explore inorder you to view the data inside your harddrive.
Please rate me SOLVED!
Nov 17, 2007 | Western Digital External USB 2.0 80 GB...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
