Question about Epson LQ-590 Matrix Printer
Epson LQ-590 Matrix Printer Paper feed Problem
As soon as the paper touches the sensor the rollers starts reverse feeding that is paper out insted of loading
  • 1 more comment
  • Anonymous Mar 23, 2014
    does not feed paper correctly, when loading paper on enters part way
  • Anonymous Mar 24, 2014
    I keep getting an error message that the printer is out of paper or that the paper is loaded incorrectly.
  • Anonymous Mar 25, 2014
    Don't feed any kind of paper at all
    Novelist:
  • 150 Answers
Assuming that you are feeding the paper into the correct end of the printer :), it seems that the printer is defective, but
First unplug the printer from the wall, wait a few minutes,
and see if it resets. If that does not work, read on.
  1. Printer rollers (and sometimes head movements as well)
    are controlled by "Stepping Motors"
    Unlike an ordinary DC motor with two wires, that spins
    clockwise or counter clockwise depending on the voltage
    polarity,
    a stepping motor contains several pairs of wires, that
    are pulsed in a controlled sequence, causing the motor
    to spin in precise angular steps. Depending on the
    number of wire pairs (poles) and internal gears, the
    stepping motor can have a resolution as course as
    90 degrees, and as fine as 0.05 degrees per step,
    depending on the cost and applications.
    Linear stepping motors can even move an object in
    a straight line.
    The benefit of these stepping motors is that, unlike a
    linear servo motor, they do not need complex positional
    feed-back for precise control, they simply step as many
    times as you tell them to. Four steps left, two steps back
    .... etc.
  2. These stepping motors are in turn driven by semiconductor switches (transistors) which are
    ultimately controlled by a central processor within the printer.
    Depending on the printer model, and how sophisticated
    the printer's internal processor is, the paper and head
    movements can be either automatically controlled by
    SOFTWARE (firmware) within the printer itself, or by the device drivers installed in Windows.
    The more self-sufficient the printer is, of course, the less
    hassle and CPU overhead on your PC.
  3. When any of the components within this chain of command fail, the stepping motor will move incorrectly:
    a) Skip steps
    b) Get stuck
    c) Oscillate back and forth
    d) Spin backwards.
  4. The causes could be:
    a) One bad wire in the ribbon connecting the motor
    to its controller board.
    b) Bad motor driver transistor: Open or shorted.
    c) Bad data line from the printer's internal control
    processor to the driver transistor array.
    d) Bad processor chip, memory or firmware within
    the printer, e.g. a burned out register or firmware
    memory location.
    e) Defective internal power supply, causing everything
    else to malfunction.
    f) Bad paper position sensor
    d) Crashed control program, which is probably the
    only thing that is fixable:
    i) unplug the printer from the wall socket, wait a
    few minutes, and see if it resets.
  5. It is also remotely (theoretically) possible, that
    the Window drivers are corrupt but this is very unlikely.
  6. If you are fairly brave and want to take the printer apart, and have some electronics knowledge and a few basic instruments, probe the roller drive motor wires, and see what gives. Is one wire stuck consistently low or high ?
    Is one of the motor windings open or shorted ?
    Is one of the driver transistors fried ?
    This very much depends on your level of skill, and the test equipment you have to work with. If you don't have a decent oscilloscope you will not get far. Without a digital multimeter you will not get anywhere at all.
Also do not forget that printers are dirt cheap, less than the ink when it runs out, so this may not be worth your time and effort.
Call the manufacturer, scream blue murder, accuse them of setting your house on fire and giving your dog diarrhea ....
and see if they will send you a freebee.
Hope this explains it.
Please rate my answers.
Martin
Posted on Jul 18, 2008
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
Hi my this model of printer is not pulling the paper..how to solve it?
Hi, Manually you can feed the paper right? top feed or front feed. LQ 300 has a sensor for paper feed, if it cannot feed paper automatically there could be something wrong with the paper feed sensor. Sensor of which is just a switch that once the paper pass, it will trigger the switch. If you can open up your printer, you can check the switch if still working. If you manage to locate the switch take out the switch and have check by ohmmeter tester to check the continuity. It sound technical but you can ask help.
Jun 21, 2011 | Epson LQ 300+ Matrix Printer
PAPER FEED WILL NOT FEED MULTI PART FORMS
Look for an adjustment that allows thicker paper/multipart forms to fit around the roller. Usually a click stop type slide near the roller.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Paper Out Sensor Not Working
try pressing the load/eject button and switch off the printer then switch on again
Jul 25, 2008 | Epson LQ-1050 Matrix Printer
Wrong adjustment using epson LQ-2180
Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
Jun 27, 2008 | Epson LQ-2180 Matrix Printer
Epson lq590
check if your LQ590 is set for manual feedor continuous feed. There is a toggle switch somewhere near the rubber rollers,there are symbols that will indicate for continuous paper printing or manual, select manual printing. Also in your print window,select printer properties, select manual printing. Yourprinter might be set up for sheet feeder or continuous paper printing. hope this helped.
Apr 23, 2008 | Epson LQ-590 Matrix Printer
Prints one line and stops
hello,
Every printer has inside Rollers that help the transportation of the paper during printing.
When the Rollers are faulty then the paper finds it difficult to move successfully during printing.
Also there is a motor that spins to rotate the Rollers.so i think any of these may be faulty.
Try and get a printer specialist to check it for you or you can come live chat with me and i will direct you..
Good luck
Jan 22, 2008 | Epson LQ-590 Matrix Printer
Epson LQ-590 Matrix Printer Logo
1,923 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
