I 've got a d530 ultraslim desktop pc without power supply. I need to modify another power supply to substitute this. I don't know pinouts of this source model. Please, sent me a table of power supply connectors. Power supply is : 150 ATX Power Supply HP-L1520F3P, P/N: 308446-001 or spare Part No: 308619-001
3 Suggested Answers
7Sleven
  • 320 Answers
SOURCE: pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Posted on Dec 28, 2010
SOURCE: Pinout for dell power supply with model number Ep071298
There are no wires, it's a big hot-swap plug.
Posted on Mar 14, 2012
What graphics card is compatable for hp d530
I'm not going to go through a list for you, but I can tell that you don't have many options. The HP Compaq Business Desktop D530 uses a small form factor which means you don't have the same space as normal desktop users inside of your machine for the vast majority of display adapters. You would need at least a medium form factor for that.
The other problem is that your power supply is only 185W and can't supply the the amount of power needed for most desktop class display adapters.
The machine you are using wasn't designed to ever be used for gaming, and it shows. You would need to get a bigger computer case and higher watt (around 400 to 600 watt) power supply to support most desktop display adapters.
Jun 26, 2012 | HP Compaq d530 CMT PC Desktop
How do I replace a power supply in a hp compaq d530 desktop? From the front, behind, top, or bottom?
the top cover should slide off from the back end remove any swrews at back before sliding cover
Mar 05, 2011 | HP Compaq d530 SFF PC Desktop
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
Dec 28, 2010 | Computers & Internet
Need the schematic to plug in the power connectors
This link http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
is a great page for the standard ATX pinout and related info.
WARNNING dell's and some other psu's have a different layout.
If you look onto the power supply box, you will see a modle like
ATX130p3, google this with "pinout".
Aug 07, 2009 | HP Compaq Evo w4000 PC Desktop
Hp compaq d530 400 watt power supply
You will not find a power supply for this case. Why would you want to upgrade such an old computer? Get yourself a new one with amply power for your needs. If you are one that upgrades regularly, get a standard case with standard components that can be upgraded without the hassle of replacing proprietary form-factor compnents.
Aug 02, 2009 | HP Compaq d530 SFF PC Desktop
Remval of power supply from hp d530 compact desktop
there are 4 screws on the back of your computer that will release the powersupply at that point you should be able to just slide it out keep mind were you unplug things
Company site http://www.attechcomputers.co.cc
Jun 18, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Replacing power source
I removed the cover, drives, motherboard, and the back plate and then the power supply just slide out the back of the case.
Aug 02, 2008 | HP Compaq d530 SFF PC Desktop
HP Compaq D530 sff Will not power up
sounds like your power supply went out.
Nov 16, 2007 | HP Compaq d530 PC Desktop
D530 Small Form Factor
From the manual:
1.Remove the computer access panel
2.Disconnect all power cables from the mass storage devices and from the system board.
3.Remove the four screws that connect the power supply to the chassis .
4.Slide the power supply toward the front of the computer, then lift it out of the computer
Here is the service manual:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00072736/c00072736.pdf
Nov 08, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP D530 SFF desktop
it is depend up on the power supply connector and it will give the output according to the smps you can do one thing try with installing other fan and see is it in perfect rotation. bye
Oct 09, 2007 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
