Question about Dishwashers
Happy holidays. wondering if you could assist me. It sounds like my motor isn't working properly on my dish washer. When I turn it on, it just hums. The water fills but also does not drain. Please help~
  • 3 Answers
Bad sighn wich means u need 2 replace it. but its cheaper 2 buy a new 1 i did it thatb way 1 time and i cost me over 890$ so its better 2 buy a new 1
Posted on Dec 29, 2010
Washer fills then shuts off
Hi scottterriz, I am happy to assist you!
Often when your washer does not spin, it is because your appliance cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance.
Hope this helps!
Feb 09, 2014 | Frigidaire GLTF2940ES Front Load Washer
EIFLS55IIW The washer is humming and starts to
Hello Chad, I am happy to assist you. Often when a unit does not complete a cycle, it is because the unit cannot properly drain and dispose of the water and detergent solution. Since the unit is making a humming noise, there is a possibility that the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. The burnt smell can be due to a faulty potential wiring failure. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 09, 2013 | Electrolux EW1000i Front Load Washer
MY AFFINITY WASHER JUST HUMS WHEN I TURN A CYCLE ON--PLEASE HELP
Good Morning Beverly, I am happy to assist you. Often when a unit hums, it is because the washer cannot properly drain and dispose of the water and detergent solution. More than likely the drainage hose/pump may be clogged and needs to be cleaned. If not, the appliance may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit. I hope this information helps in a small way.
Aug 09, 2013 | Frigidaire Affinity ATF7000E Front Load...
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
Dish Network 6.0 Remote Control TV2 stops working when the PS3 is turned on on TV1
I would be happy to assist you! It sounds like the PS3 is causing interference. In this case, we would do what we call backfeed the remote so that the game console can no longer interfere with the remote. Please email me at becki.barned@dish.com so that I can assist you. Thank you!
Becki Barned
DISH Internet Response Team
Dec 07, 2012 | Televison & Video
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Washing machine not working there is water and power.
check the "capacitor" (cylinder like battery but bigger), that part helps the motor running. if the capacitor not working properly, the motor won't start. sometime sounds like humming inside your machine. the part isn't expensive.
Jul 19, 2011 | Washing Machines
My Maytag Epic Z washer stop in mid cycle then locked the door, we unlock the door via holding the cycle signal button down for 3 seconds, now we can open the door, close it, power up, start a cycle, but...
The low humming sound is from the pump. Remove the 3 screws on the bottom panel and remove it to check the pump filter. Here is a video for the "Duet Sport" washer. This washer is about the same. This video will show you the process and in this video the problem was similar to yours.
Happy Holidays The FixYa Team
Dec 19, 2010 | Maytag MHWZ600TB Front Load Washer
I have a dish network in sanjose la playita bcs. and i wons wondering how to readjust it
It sounds like you were wanting your dish satellite readjusted, ipailo, is that correct? If so, what is the problem with it? Are you having issues with the signal? Let me know in a little bit more detail and I would be more than happy to assist you further with that!
Oct 29, 2010 | RCA DISH Network(r) 311 Satellite System
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
