SOURCE: Averatec Laptop computer-
This could be a simple glitch, but most likely the screen is going out and will need replaced. Start by adjusting the screen resolution in the display properties. Adjust it to a lower setting, apply, then adjust it back to where it was, and apply. If this doesn't work, then try uninstalling the video drivers from the device manager and rebooting. The machine will automatically find the video and reinstall the drivers. By doing these two, you have just ruled out a software glitch and narrowed it down to hardware, so, if the problem persists, then it's the screen and will need replacing.
SOURCE: fn key is stuck on Averatec 1000 series how do i turn it off
you might want to not tapit alot fi you want to take that key off you keyboard under it is a soft flexible rubber material that might be stuck or something sticky might be on it if you cant get your key of you can get it off with a screw driver
SOURCE: Adding ram to averatec 3715-EH1 laptop
Hi there.
Its fairly easy to upgrade the system memory on a laptop, if you turn the laptop upside down there should be a panel with a couple of screws, like this >>>>>>>
Take the ram out and take it with you when you go to purchase your new ram, at least then you are making sure you getting the correct ram modules.
Good luck and thanks for choosing FixYa!!
