Apple iPhone 3G Logo
Pat Nash Posted on Dec 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cancel button not working properly - Apple iPhone 3G
JDTec
Level 3:
  • Apple Master 4,338 Answers
  • Posted on Dec 28, 2010
JDTec
Apple Master
Level 3:
Answers
4338
Questions
0
Helped
2127936
Points
14653
Try a reset:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Affinity ATF6700 washer has 'err' in display, I can't press any buttons, unplugging it did nothing.
Question edited for clarity.
Question moved to Affinity.
Try a full system reset. If that doesn't work, you need a service call.
Resetting the Frigidaire Affinity washer
  • Unplug the power source or turn the circuit breaker off for a few seconds.
  • Then plug the power back on to reset the washer to default settings.
  • Now press the cancel button to cancel all commands.
  • And in the next step press and hold the spin speed and soil level buttons together for four to eight seconds.
  • Hold the buttons until you hear some signal sounds and then leave the buttons.
  • After that open the door for more than 2 times and make sure it gets closed again each time. After this, your machine has been properly restored to proper default settings. This will lead your machine to work properly again.
Please instruct me how to change the regional code of Canon PIXMA MP980 printer USA vesion to Australia version. Thank you in advance. Anh Tran
Make sure the printer is turned off
Hold the red “Cancel/reset” button (top right corner on control panel) down with a finger on your right hand
Press and HOLD DOWN the “Power” button
Let go of the “Cancel/reset” button and then press it twice
Let go of the “Power” button
Wait for the “Copy” button to stop flashing and go solid green
Press the “Cancel/reset” button five times
Press the “Power” button once
Now press the “Cancel/reset” button 5 times.
Press the “Power” button one more time to commit the setting
Press the “Power” button again to turn off the printer
Your printer should now be set properly and you just turn on as normal.
I want to print some thing and when I try to print it ,is appearin on my laptop error number 5011 . What did it mean ?
It indicates that the scanner bulb may not be heating up fast enough for the printer to work properly.
I found this fix on another forum. Sounds like it's worth a try:
With the printer off, press and hold power+cancel simultaneously,
Release cancel but keep power button pressed,
Press cancel button 4 times,
Release both.
I don't know what this does exactly, but it seems to reset something and make a fresh start, the printer will take longer to resume the power on sequence.
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
1helpful
I am trying to print a large picture on the 110plus and I am getting horizontal lines throught the image. Any Ideas?
Print head nozzles are clogged.This utility helps maintain proper operation of all nozzles in the printheads. This is only recommended if you are experiencing problems with print quality such as banding.Three levels of recovery are available: soft, medium and hard. As a first step, the soft recovery should be used. If you still experience the same image problems, then select medium. Hard recovery should only be used as a last resort.
Perform the print head recovery
For level 1 soft: Hold on button then press twice cancel button
level 2 medium: Hold on button press teice cancel button then resume button once
level 3 hard: Hold on button press twice cancel button then resume button twice.
after completion of this process check the print quality, still not resolved replace print heads which print head not recovered.
The ink apsorber is full. contact the service center.
TRY THIS
Canon iP4500 waste ink reset:
1) With the machine power turned off, while pressing the Resume/Cancel button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Resume/Cancel button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Resume/Cancel button 2 times, and then release both the ON/OFF and Resume/Cancel buttons.
4) When the Power LED lights in green press the Resume/Cancel button 4 times
then press the ON/OFF button.
IF THAT DOESN'T WORK TRY THIS
I believe you need software from Canon to reset the ink pad full error code for that printer. Here is a link where you might be able to download it: The file name you are looking for is mypwin210aen.exe or mypwin210en.exe i don't know which version will work best for you. If these don't work then try calling Canon for information on where to find the proper program
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Although I have loaded my paper properly (i've been using this printer for over a year) it will not feed I get the error message that the paper is not loaded properly. I have tried to reload the paper and...
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
Brake lights don't work, but fuses are alright
Check to make sure the button above the brake pedel is not stuck in when you hit the brakes. If that is free and working properly your multi function switch on the steering colum is probably bad. The brake light canceler can go bad in these causing no brake lights. The canceler cancels the brake light when the turn signal is on. but sometimes they go bad and cancel both brake lights all the time. So be sure and check to make sure the hazard button is push all the way in before changing the muti fucntion switch. Oh and check the bulb first too of course. Good luck
KESA907P Electric Kitchen Range: Oven comes on but the off button will not work. H...
It sounds like it could be a stuck off/cancel button on the touch panel. When you push the off/cancel button does it feel like the other buttons or different. Usually when these buttons get stuck the proper repair is to replace the touch pad. Some of the newer ranges will produce an error code on the display when a touch panel button is stuck but not always. Unplugging the power to the range might work for turning off the oven but is not recommended. If everything else is functioning properly except for the off/cancel button then it sounds like the touch panel may need to be replaced.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
