Question about Compaq Presario R3000 Notebook
My compaq presario r3000 wont charge. its plugged in but when i unplug it it immediatly turns off. the battery life constantly says 0%. it wont drop from that or get any higher. in the bottom right hand corner it says ac power but like i said it wont charge.
  • 3 Answers
Sounds like the battery, had similar problems.. if you purchase a new battery make sure you get the right kind there are two types, an 8 cell or 12 cell..
The fix for my pressario involved completely stripping it and soldering 3 pins on the power connector on the mainboard.. not difficult but no mean feat.. now works perfectly (with the inclusion of a 12cell battery)
Posted on Dec 31, 2010
    Genius:
  • 1,288 Answers
Depending on the age of the battery it may be past its ability to accept a charge, solution, new battery.
Posted on Dec 28, 2010
  • Compaq Master
  • 6,771 Answers
Try and remove the main battery, get a toothbrush and clean the metal pins on the battery and the matching pins in the battery compartment. Put the battery back in to see if it will take a charge, if it does, leave it overnight, failing that it means the battery is completely dead, or in very rare cases the charging circuit in the laptop is not working.
2 Suggested Answers
Make_toast
  • 10 Answers
SOURCE: wont charge
It could be that your battery is defective/worn out. If the computer just shuts off immediately (doesnt try to hibernate/standby) then you're likely looking at replacing the battery. They can suddenly do things like this if a cell shorts out in the battery or due to common wear. But first, here are a couple of things you can try.
1. Try reseating the battery (pull it out and put it back in). Sometimes something that simple can fix the problem.
2. Try to calibrate the battery. Your computer may come with instructions on how to do this, but if not you can do it manually. Turn the computer on but go into BIOS (press F10 at the compaq logo screen). Don't load your operating system
Unplug your computer. If it turns off at this point, your battery is already toasted. Replace it.
If the computer keeps running, let it go until it finally shuts off due to battery drain. Then plug it back in and let it recharge completely. This will let the microchip in the battery learn its charge potential and may allow you to get more life out of it.
Note: Calibrating these batteries is good practice but it shouldn't be done very often. If your calibration doesn't work after 1 or 2 tries, you probably still are looking at a dead battery.
Posted on Apr 23, 2008
My compaq presario c795tu battery is not charging
Unplug the power supply, take a stiff tooth brush and clean the battery terminals in the laptop plus the battery, re-install the battery and plug the charger in, If that fails you need to find out if the charging circuits are putting out the proper voltage before you replace the battery.
Mar 04, 2012 | HP Compaq Presario CQ40-330TU
Computer wont charge the light comes on every few mins for about a min then goes off i can turn it on but only stays on a few mins i have a compaq presario r3000
The lithium batteries that laptops use have a 3 year lifespan. If you have had the battery for that amount of time then you have reached the end of it's life cycle. Most manufacturers build in a warning message that will pop up to let you know that you have reached that time frame and it is time to change the battery. If your battery is not that old then you have an issue either with the battery itself or the charging system built into the laptop. The only way to identify what the problem is would be to switch out the battery to another laptop and see if it would charge properly. If you do not have any access to the same model of laptop that you are currently using then the other choice would be to take your unit into your local HP-Compaq repair center. Usually the batteries are warranted for as long as the original warranty period on your laptop. The warranty would not cover the life cycle. If age is the problem then your only recourse is to buy another battery.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 15, 2011 | Compaq Presario R3000 Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
R3000 DC025052300 unplugged
Right after the rj11 jack where you plug your landline in. You can follow the leads easy from the jack. Opposite side of the processor side.
Jan 30, 2009 | Compaq Presario R3000 Notebook
The power plug won't charge the battery which prevents the computer coming on
There was a recent class settlement agreed to by HP regarding these models. HP failed to notify a ton of its customers and I've contacted Scott Kamber regarding.. (We were consultants for the suit).. Weve repaired a ton of these and you are not alone. Did you buy the machine new and register w/HP? Just curious...
Ken
Aug 02, 2008 | Compaq Presario R3000 Notebook
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
Wont charge
Apr 23, 2008 | Compaq Presario R3000 Notebook
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
154 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
